loglevel grade erst wieder hochgestellt. nextcloud ist 12.0.2.
der issue reporter ist ja nett, man muß allerdings noch jede Menge Daten rauslöschen, wenn man nicht grade seine urls usw. preisgeben möchte.
Danke!
Steps to reproduce
- change domain from owncloud.xyz.de to nextcloud.xyz.de
- change certificate to letsencrypt certificate
- change php from 5.6 to 7.1
- change trusted domains in config.php
Expected behaviour
Everything should work fine
Actual behaviour
Nextcloud via Webbrowser works without faults, but carddav/caldav/webdav clients say the login credentials are wrong. however, i can login via webbrowser with the same credentials.
General server configuration
Operating system: Linux sh8-33 4.4.0-72-generic #93-Ubuntu SMP Fri Mar 31 14:07:41 UTC 2017 x86_64
Web server: Apache (cgi-fcgi)
Database: mysql 5.7.19
PHP version: 7.1.7
PHP-modules loaded
- Core
- date
- libxml
- openssl
- pcre
- sqlite3
- zlib
- bcmath
- bz2
- calendar
- ctype
- curl
- dba
- dom
- hash
- fileinfo
- filter
- ftp
- gd
- gettext
- gmp
- SPL
- iconv
- session
- intl
- json
- ldap
- mbstring
- mcrypt
- mysqli
- pcntl
- PDO
- pdo_dblib
- pdo_mysql
- PDO_ODBC
- pdo_pgsql
- pdo_sqlite
- pgsql
- standard
- posix
- pspell
- Reflection
- imap
- shmop
- SimpleXML
- snmp
- soap
- sockets
- Phar
- exif
- sysvmsg
- sysvsem
- sysvshm
- tokenizer
- wddx
- xml
- xmlreader
- xmlwriter
- xsl
- zip
- cgi-fcgi
- Zend OPcache
Nextcloud configuration
Nextcloud version: 12.0.2 - 12.0.2.0
**Updated from an older Nextcloud/ownCloud or fresh install: Updated
**Where did you install Nextcloud from: nextcloud website
Are you using external storage, if yes which one: files_external is disabled
Are you using encryption: no
Are you using an external user-backend, if yes which one: YOUR ANSWER HERE (Webdav/Caldav/Carddav)
Signing status
Enabled apps
- activity: 2.5.2
- admin_audit: 1.2.0
- audioplayer: 2.1.0
- bookmarks: 0.10.1
- bruteforcesettings: 1.0.2
- calendar: 1.5.3
- comments: 1.2.0
- contacts: 1.5.3
- dav: 1.3.0
- federatedfilesharing: 1.2.0
- federation: 1.2.0
- files: 1.7.2
- files_pdfviewer: 1.1.1
- files_sharing: 1.4.0
- files_texteditor: 2.4.1
- files_trashbin: 1.2.0
- files_versions: 1.5.0
- files_videoplayer: 1.1.0
- firstrunwizard: 2.1
- gallery: 17.0.0
- issuetemplate: 0.2.2
- logreader: 2.0.0
- lookup_server_connector: 1.0.0
- nextcloud_announcements: 1.1
- notes: 2.3.1
- notifications: 2.0.0
- oauth2: 1.0.5
- password_policy: 1.2.2
- provisioning_api: 1.2.0
- serverinfo: 1.2.0
- sharebymail: 1.2.0
- survey_client: 1.0.0
- systemtags: 1.2.0
- theming: 1.3.0
- twofactor_backupcodes: 1.1.1
- updatenotification: 1.2.0
- user_external: 0.4
- workflowengine: 1.2.0
Disabled apps
- encryption
- files_external
- keeweb
- spreed
- user_ldap
Content of config/config.php
"instanceid": "ocrq5xn56rwj",
"nextcloud.xyz.de"
"datadirectory":
"overwrite.cli.url":
"overwriteprotocol": "https",
"forcessl": true,
"forceSSLforSubdomains": true,
"dbtype": "mysql",
"version": "12.0.2.0",
"dbname": "
"dbhost": "
"logtimezone": "Europe\/Berlin",
"mail_from_address":
"mail_smtpmode": "php",
"mail_domain":
"loglevel": 2,
"theme": "",
"trashbin_retention_obligation": "auto",
"updater.secret": "***REMOVED SENSITIVE VALUE***"
Client configuration
Browser: Mozilla/5.0 (Windows NT 10.0; WOW64; rv:52.0) Gecko/20100101 Firefox/52.0
Operating system: YOUR ANSWER HERE
Logs
Web server error log
Insert your webserver log here
Nextcloud log (data/nextcloud.log)
Insert your Nextcloud log here
Browser log
Insert your browser log here, this could for example include:
a) The javascript console log
b) The network log
c) ...
