Login flow errors and links not opening. MacOSX Ventura 13.4 and Nextcloud Desktop v3.8.2
I am trying to install nextcloud desktop v3.8.2 on ventura 13.4 but am running into some issues.
Screenshot 2023-05-25 at 3.56.15 PM
The Copy Link and Reopen Browser option do not work. Note that I can successfully post to the login flow endpoint index.php/login/v2 and get the json object with poll, token, endpoint and login back using curl from my command line which gives me back a working login url.
Any suggestions on how to address this?
I am running dockerized nextcloud behind a cloudflare tunnel. The version of nextcloud that I am running is Nextcloud Hub 4 (26.0.1) and the clients are working on my windows machines and android device. Those installs are old and it is not a fresh desktop client install like I am trying on MacOSX, so maybe it is something to some settings I changed a long time ago or it is the client. To me it seems that the MacOS desktop client is incorrectly trying to access the index.php/login/v2 endpoint as I can curl it through the command line without issues as well as being able to access the instance in my browser.
