example
longer
example
here
Nextcloud version : 13.0.3.2
Operating system and version: Debian 8
Apache or nginx version : Apache/2.4.10
PHP Version: 5.6.26-0+deb8u1
The issue you are facing: When I try to access to my NextCloud with my user and password, NextCloud redirects me mydomain.com/index.php to /index.php/login?redirect_url=/index.php/apps/files/, so I can not enter
Is this the first time you’ve seen this error? (Y/N): Yes
- I migrated OwnCloud to NextCloud
- I solved the problems with integrity
- I tryed to change my background and logo image
- I put a .jpg image
- When I log out, in tryed to log in again, I could not
** I put the custom theme ‘example’, and I cant log in anyway.
I cant enter
'datadirectory' => '/var/www/owncloud/data',
'overwrite.cli.url' => 'http://xxxxxx/owncloud',
'version' => '13.0.3.2',
'dbname' => 'owncloud',
'dbhost' => 'localhost',
'dbtableprefix' => '',
'dbuser' => 'xxxxx',
'dbpassword' => 'xxxxxx',
'logtimezone' => 'UTC',
'forcessl' => true,
'mail_smtpmode' => 'php',
'mail_from_address' => 'postmaster',
'mail_domain' => 'xxxxxxxxx',
'log_rotate_size' => '104857600',
'loglevel' => 3,
11.11.111.11 - - [08/Jun/2018:09:38:38 +0200] "GET /index.php/login?redirect_url=/index.php/apps/files/ HTTP/1.1" 200 4449 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36"
/data/nextcloud.log
{"reqId":"TFWEw70prlAbNXqtBcwP","level":3,"time":"2018-06-08T06:55:15+00:00","remoteAddr":"46.24.120.90","user":"Adrian","app":"index","method":"GET","url":"\/data\/.ocdata?t=1528440672859","message":"Exception: {\"Exception\":\"Exception\",\"Message\":\"The requested uri(\\\/data\\\/.ocdata) cannot be processed by the script '\\\/owncloud\\\/index.php')\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/lib\\\/base.php(951): OC\\\\AppFramework\\\\Http\\\\Request->getRawPathInfo()\\n#1 \\\/var\\\/www\\\/owncloud\\\/index.php(42): OC::handleRequest()\\n#2 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Request.php\",\"Line\":733}","userAgent":"Mozilla\/5.0 (Macintosh; Intel Mac OS X 10_13_2) AppleWebKit\/537.36 (KHTML, like Gecko) Chrome\/66.0.3359.181 Safari\/537.36","version":"13.0.3.2"}
