Logging from tablet is refused
  • Nextcloud Server version:
    • Nextcloud 31.0.4
    • #1 SMP PREEMPT Debian 1:6.12.25-1+rpt1 (2025-04-30)
  • Web server and version:
    • Server version: Apache/2.4.62 (Debian)
  • Reverse proxy and version:
    • nginx version: openresty/1.27.1.1
  • PHP version:
    • PHP 8.3.20 (cli) (built: Apr 11 2025 17:51:27) (NTS)
    • yes
    • prob direct after installation
    • OMV Container
    • nope
I see the “We have detected multiple invalid login attempts…” message. I can no longer logon neither as user nor as administrator
  1. Install Nextcloud on Android
  2. Logon a browser window opens
  3. I see this message and logon is denied
I'm unable to provide the logs as I cannot logon.
The console.log is empty
PASTE HERE
bash: occ: command not found
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'redis' =>
    'host' => 'redis',
    'password' => '',
    'port' => 6379,
  'instanceid' => 'oc6oc6hi85a5',
  'passwordsalt' => 'is this all the identifiable information you are referring to?',
  'secret' => 'is this all the identifiable information you are referring to?',
    0 => 'srv-nas-pi.kingma:8080',
    1 => 'office.kingma.ch',
    2 => 'office.king.ma',
  'overwrite.cli.url' => 'http://srv-nas-pi.kingma:8080',
  'version' => '31.0.4.1',
  'dbname' => 'nextcloud',
  'dbhost' => 'nextclouddb',
  'dbuser' => 'nextcloud',
  'dbpassword' => 'is this all the identifiable information you are referring to?',
  'mail_smtpmode' => 'smtp',
  'mail_from_address' => 'theking2',
  'mail_domain' => 'king.ma',
  'mail_smtphost' => 'cicero.metanet.ch',
  'mail_smtpport' => '465',
  'mail_smpttimeout' => 30,
  'mail_smtpsecure' => 'ssl',
  'loglevel' => 3,
  'maintenance_window_start' => 3,
  'default_phone_region' => 'CH',
This template does not help me to understand what you mean by identifiable information
How do I logon with the qr code? Where do I find this?
thanks, doesn´t help
What doesn’t help?
Something in your environment is triggering BFP. There are troubleshooting steps in there, including methods for turning on additional logging/etc.
The most common cause is having a misconfiguration with regards to your reverse proxy. Your config appears to not even reference a trusted_proxy but it also sounds like you’re using one. That may be, at least in part, the problem.
