Nextcloud Box: After installation the locale settings default to the US (yawn).
On running an update a bunch of Locale errors are generated:
... locale: Cannot set LC_CTYPE to default locale: No such file or directory locale: Cannot set LC_MESSAGES to default locale: No such file or directory locale: Cannot set LC_ALL to default locale: No such file or directory
This can be fixed by correcting the locale settings. In my case for en_GB.
:~$ sudo locale-gen en_GB.UTF-8 :~$ sudo update-locale LANG=en_GB.UTF-8
Keyboard is now no longer the damned annoying US default version and the error messages go away.
