Hum. Unfortunately it did not work. I can not see my external hard drive. I mean, I can see it, but it says that O do not have permission to write or read.
I used
‘’‘docker logs -f nextcloudpi’’’
And then:
‘’‘docker update --restart=always IDCONTAINER’’’
Is there any other easy way to install ncpi? Is it easier to install ncpi iso?
Thank you for your time, OliverV.
Those are not commands to start a container, but to view logs and auto restart… Which command did you use to start the currently running container?
Docker is the easy way of getting started, but installing to sd-card with latest image is also relatively simple.
Hello. I have made this command you said
And then
And then:
‘’‘docker update --restart=always IDCONTAINER’‘’
But I have decided to move on and install iso file and completely worked. Everything was automatic. Thank you so much.
I just have one doubt. Where should I place my data, because now I can see all the contents of the /media folder in my nextcloud. For example: I can open media folder, and then my cloud storage and then ncdata. Which folder should I place my data in? Could I configure that external storage to only show that specific folder?
I searched for the answer all day in the forum and I didn’t find it. Please if it was already answered could you send me the link?
Of course! Just check this screenshot from above. Instead of /mnt/lvm/
you have to write something like /mnt/localFolder1/Your/Specific/Subfolder/ToShow
Thank you very much.
Now everything is working
The snap connect command for removable media solved my issue. Thank you!
I realize this post is very old, but I just mounted my samba share here manually and it works. I’m just concerned that this somehow presents a security risk… any idea if the access to this space is not as stringent?
