Linode Market Place AIO Eventually Consumes 100% CPU
I run Nextcloud AIO on a Linode that was created using the Linode marketplace. I have a mild irritation that I keep putting off investigating. About every two weeks, the system is consuming 100% of CPU. After a reboot the CPU usage drops to around 10-30%.
I grabbed the reboot events and they are consistently space at 12 day intervals.
I mean I can continue to just log in and reboot every couple of weeks but it’d be nicer if I didn’t have to. TBH I was hoping a search of posts for Linode would surface up a bunch of posts where this is known behaviour and here’s the fix. But maybe it’s just me…
Nextcloud version (eg, 20.0.5): 27.1.5
Operating system and version (eg, Ubuntu 20.04): Ubuntu 22.04
Apache or nginx version (eg, Apache 2.4.25): 2.4.58
PHP version (eg, 7.4): Not sure where to find this sorry
Eventually Nextcloud will consume 100% CPU. Requires a reboot to fix
Let the system run as normal for 12 days and CPU usage will have increased to 100% and the system will stop responding.
{"reqId":"kcGQX7NuRYYy1aGSDaf0","level":3,"time":"2024-02-14T23:35:06+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"KjuLKWfFZW1xngDT1E2y","level":3,"time":"2024-02-15T00:05:12+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"cRhVohdBeiD4A3kYpG46","level":3,"time":"2024-02-15T00:40:07+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"GwKYjkKYZCil2vO2WMDv","level":3,"time":"2024-02-15T01:10:12+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"KmwlUxRRK5jxo8iBAebt","level":3,"time":"2024-02-15T01:45:07+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"iowsu5DPLVljvHtLo6r1","level":3,"time":"2024-02-15T02:15:09+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"qEgh28DbhMwPMjIwkvdJ","level":3,"time":"2024-02-15T02:50:10+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"b06cY5yFetWOPsT62Ugv","level":3,"time":"2024-02-15T03:25:06+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"zVp4oFzkhJxZQvdZu87r","level":3,"time":"2024-02-15T03:56:32+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"Tk8Umakc2BaQzCdLixd8","level":3,"time":"2024-02-15T04:31:11+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"kE9bjGna0nYn2qZASpBn","level":3,"time":"2024-02-15T05:01:23+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"myu58Hlax9u0AxoJ7HWA","level":3,"time":"2024-02-15T05:36:11+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"AosQ6773ThGaXwvL2E0P","level":3,"time":"2024-02-15T06:06:23+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"obUqNDXjoH3hRdhmssWx","level":3,"time":"2024-02-15T06:41:12+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"shbysQ5fSPQLFMlf3vWv","level":3,"time":"2024-02-15T07:11:23+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"eHzSvXztk5lmmtI0VSfY","level":3,"time":"2024-02-15T07:46:12+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"6bX0e6vYV0N1VZVcoyGQ","level":3,"time":"2024-02-15T08:16:23+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"taomNzedrzurdX4DK1X2","level":3,"time":"2024-02-15T08:51:12+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"oidzSY5Nn8SUYucheHJt","level":3,"time":"2024-02-15T09:21:17+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"dbsuFo281M8fjOABRrFX","level":3,"time":"2024-02-15T09:56:22+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"dHItfWUvElYQXbFa4z4e","level":3,"time":"2024-02-15T10:31:08+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"MTvW3SQXfVAgaiiUufOO","level":3,"time":"2024-02-15T11:01:13+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"XHpsJmnec3coGHGmYpZB","level":3,"time":"2024-02-15T11:36:08+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"CVovE5lPYfCwUNLAyMmb","level":3,"time":"2024-02-15T12:06:12+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"P0vJBVrUFfjVzmEhMOQa","level":3,"time":"2024-02-15T12:41:08+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"QctUjmmjTFSsgnwek8hr","level":3,"time":"2024-02-15T13:11:13+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"NDVrQ30TCZKouoSfNaTF","level":3,"time":"2024-02-15T13:46:09+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"YFFVFj47GWGvJ9AQlMd1","level":3,"time":"2024-02-15T14:16:13+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"uv1MBfXGSFTRxR1daPTn","level":3,"time":"2024-02-15T14:46:13+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"reDYKTSC2VEnXO1zU5Vh","level":3,"time":"2024-02-15T15:21:12+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"kF8DnrYMz0rBYyFfnW1Q","level":3,"time":"2024-02-15T15:51:13+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"nY3NrEouGF9PU48RfCTb","level":3,"time":"2024-02-15T16:26:21+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"mwzDX33IuzBq8MmQEXax","level":3,"time":"2024-02-15T17:01:09+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"R3MvFADKiuoXbB7WSA91","level":3,"time":"2024-02-15T17:31:12+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"yOCHjlxuRwBIF7Q4faHc","level":3,"time":"2024-02-15T18:01:14+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"lVEgjRwnHsVlPpLeKIvK","level":3,"time":"2024-02-15T18:34:05+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"4aJLsFBKcpPicGPFcHGx","level":3,"time":"2024-02-15T19:09:05+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"zwAb9em7XshBSZcnSIqM","level":3,"time":"2024-02-15T19:44:06+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"XVxCCY5VylMsZxIAYJka","level":3,"time":"2024-02-15T20:19:06+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"NI6oWxRMOoGA3Pz2EWfy","level":3,"time":"2024-02-15T20:54:04+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"HXLAmx8iDLXzSYGID8Lk","level":3,"time":"2024-02-15T21:24:06+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"izJoSThRtzWeMAOn38uX","level":3,"time":"2024-02-15T21:59:08+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"1RPJ8RXjfbaKM7Wqmcp2","level":3,"time":"2024-02-15T22:34:06+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"A4oAIUFRMqZyCmCk28Bl","level":3,"time":"2024-02-15T23:04:22+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"WvGg50COneJYdEzSuEHT","level":3,"time":"2024-02-15T23:39:04+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"1pkUKuaI3zGP7ciI4Vgx","level":3,"time":"2024-02-16T00:13:46+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"sHtv1oXtEUYs6xmSbf49","level":3,"time":"2024-02-16T00:48:45+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
{"reqId":"cZe4SJcsJhVDAMHqQjaV","level":3,"time":"2024-02-16T01:23:45+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"file_put_contents(/mnt/ncdata/appdata_ocdf348gpa16/bookmarks/cache/CACHEDIR.TAG): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#328","userAgent":"--","version":"27.1.5.1","data":{"app":"PHP"}}
/Var/log does not contain a file or directory for apache or nginx
PASTE HERE
PASTE HERE
```There is no /var/www directory
This is the CPU graph for the past 30 days showing the consistency of the issue.
