using the wizard the following services all have green light :
freeDNS
nc-autoupdate-ncp
dnsmasq
I get orange for
letsencrypt
here’s the message the wizard gives:
[ letsencrypt ] (Wed Sep 30 15:24:30 BST 2020)
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator webroot, Installer None
Obtaining a new certificate
Performing the following challenges:
http-01 challenge for sherab.uk.to
Using the webroot path /var/www/nextcloud for all unmatched domains.
Waiting for verification…
Cleaning up challenges
Failed authorization procedure. sherab.uk.to (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://sherab.uk.to/.well-known/acme-challenge/9YP0-T96jtQLOPXqYotaoi2HBIor_DLMQaIKw9gOI1g [95.146.137.2]: "\n<html class=“ng-csp” data-placeholder-focus=“false” lang=“en” data-locale=“en” >\n\t<head\n data-requesttoken=“V7Y+”
IMPORTANT NOTES:
- The following errors were reported by the server:
Domain: sherab.uk.to
Type: unauthorized
Detail: Invalid response from
[95.146.137.2]: "<!DOCTYPE html>\n<html class=\"ng-csp\"
data-placeholder-focus=\"false\" lang=\"en\" data-locale=\"en\"
>\n\t<head\n data-requesttoken=\"V7Y+"
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address.
I would appreciate any advice to fix this.
Thank you
