Hallo,
I try install Nextcloud with Docker after a Reverse Proxy. The Nexcloud Container runs probarly but wen my Let’s Encrypt Container try to validate my Domain name i got an validation Error. I try many thing but I could not solve this problem. May be some one has an idea or may be help me.
Thanks for supporting.
Here the Error message:
[Sun Dec 19 15:47:00 UTC 2021] Verifying: cloud.meinedomain.de.de
[Sun Dec 19 15:47:03 UTC 2021] cloud.meinedomain.de.de:Verify error:Invalid response from http://cloud.meinedomain.de.de/.well-known/acme-challenge/wA32DiXMF60dQgaST82qrR59yjJe8KXpppBXWJUj1jk [194.36.145.30]:
[Sun Dec 19 15:47:03 UTC 2021] Please check log file for more details: /dev/null
Here my Docker YML File:
version: '3.7'
services:
nextcloud_datenbank:
image: postgres:13
container_name: nextcloud_db
restart: always
networks:
ExtNet:
ipv4_address: 172.18.4.1
environment:
- POSTGRES_USER=nextcloud_usr
- POSTGRES_PASSWORD=myPassword
- POSTGRES_DB=nextcloud
volumes:
- /daten/docker/nextcloud_db/postgres/13:/var/lib/postgresql/data
nextcloud_redis:
image: redis:alpine
container_name: nextcloud_redis
restart: always
nextcloud_cron:
image: nextcloud:fpm-alpine
container_name: nextcloud_cron
restart: always
volumes:
- /daten/docker/nextcloud_html:/var/www/html
entrypoint: /cron.sh
depends_on:
- nextcloud_datenbank
- nextcloud_redis
nextcloud_server:
container_name: nextcloud_server
networks:
ExtNet:
ipv4_address: 172.18.4.4
environment:
- POSTGRES_HOST=db:5432
- REDIS_HOST=nextcloud_redis
restart: always
volumes:
- /daten/docker/nextcloud/html:/var/www/html
- /daten/docker/nextcloud/config:/var/www/html/config
- /daten/docker/nextcloud/custom_apps:/var/www/html/custom_apps
- /daten/docker/nextcloud/data:/var/www/html/data
- /daten/docker/nextcloud/themes:/var/www/html/themes
- /etc/localtime:/etc/localtime:ro
depends_on:
- nextcloud_redis
nextcloud_web:
image: nginx:alpine
container_name: nextcloud_web
networks:
ExtNet:
ipv4_address: 172.18.4.5
environment:
- VIRTUAL_HOST=cloud.meinedomain.de
- LETSENCRYPT_HOST=cloud.meinedomain.de
- LETSENCRYPT_EMAIL=letsencrypt@meinedomain.de
restart: always
volumes:
- /daten/docker/nextcloud_web/nginx.conf:/etc/nginx/nginx.conf
- /daten/docker/nextcloud/html:/var/www/html:ro
depends_on:
- nextcloud_server
networks:
ExtNet:
external: true
and here the nginx config file for the web container:
worker_processes auto;
error_log /var/log/nginx/error.log warn;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
include /etc/nginx/mime.types;
default_type application/octet-stream;
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log /var/log/nginx/access.log main;
sendfile on;
#tcp_nopush on;
keepalive_timeout 65;
#gzip on;
upstream php-handler {
server nextcloud_server:9000;
server {
listen 80;
# HSTS settings
# could take several months.
#add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always;
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
# Pagespeed is not supported by Nextcloud, so if your server is built
# with the `ngx_pagespeed` module, uncomment this line to disable it.
#pagespeed off;
# HTTP response headers borrowed from Nextcloud `.htaccess`
add_header X-Download-Options "noopen" always;
add_header X-Permitted-Cross-Domain-Policies "none" always;
add_header X-Robots-Tag "none" always;
add_header X-XSS-Protection "1; mode=block" always;
# Remove X-Powered-By, which is an information leak
root /var/www/html;
# Specify how to handle directories -- specifying `/index.php$request_uri`
# here as the fallback means that Nginx always exhibits the desired behaviour
# when a client requests a path that corresponds to a directory that exists
# on the server. In particular, if that directory contains an index.php file,
# that file is correctly served; if it doesn't, then the request is passed to
# the front-end controller. This consistent behaviour means that we don't need
# to specify custom rules for certain paths (e.g. images and other assets,
# `/updater`, `/ocm-provider`, `/ocs-provider`), and thus
# `try_files $uri $uri/ /index.php$request_uri`
# always provides the desired behaviour.
index index.php index.html /index.php$request_uri;
# Rule borrowed from `.htaccess` to handle Microsoft DAV clients
location = / {
if ( $http_user_agent ~ ^DavClnt ) {
return 302 /remote.php/webdav/$is_args$args;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
# Make a regex exception for `/.well-known` so that clients can still
# access it despite the existence of the regex rule
# `location ~ /(\.|autotest|...)` which would otherwise handle requests
# for `/.well-known`.
location ^~ /.well-known {
# The rules in this block are an adaptation of the rules
# in `.htaccess` that concern `/.well-known`.
location = /.well-known/carddav { return 301 /remote.php/dav/; }
location = /.well-known/caldav { return 301 /remote.php/dav/; }
location /.well-known/acme-challenge { try_files $uri $uri/ =404; }
location /.well-known/pki-validation { try_files $uri $uri/ =404; }
# Let Nextcloud's API for `/.well-known` URIs handle all other
# requests by passing them to the front-end controller.
return 301 /index.php$request_uri;
# Rules borrowed from `.htaccess` to hide certain paths from clients
location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)(?:$|/) { return 404; }
location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console) { return 404; }
# Ensure this block, which passes PHP files to the PHP process, is above the blocks
# which handle static assets (as seen below). If this block is not declared first,
# then Nginx will encounter an infinite rewriting loop when it prepends `/index.php`
# to the URI, resulting in a HTTP 500 error response.
location ~ \.php(?:$|/) {
# Required for legacy support
rewrite ^/(?!index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|oc[ms]-provider\/.+|.+\/richdocumentscode\/proxy) /index.php$request_uri;
set $path_info $fastcgi_path_info;
include fastcgi_params;
fastcgi_param PATH_INFO $path_info;
#fastcgi_param HTTPS on;
fastcgi_param modHeadersAvailable true; # Avoid sending the security headers twice
fastcgi_param front_controller_active true; # Enable pretty urls
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ~ \.(?:css|js|svg|gif)$ {
expires 6M; # Cache-Control policy borrowed from `.htaccess`
access_log off; # Optional: Don't log access to assets
location ~ \.woff2?$ {
expires 7d; # Cache-Control policy borrowed from `.htaccess`
location /remote {
return 301 /remote.php$request_uri;
location / {
try_files $uri $uri/ /index.php$request_uri;
