Hallo nochmal,
in der Datei
root@raspberrypi-iob:/etc/apache2# pwd
/etc/apache2
root@raspberrypi-iob:/etc/apache2# cat ports.conf
# If you just change the port or add more ports here, you will likely also
# have to change the VirtualHost statement in
# /etc/apache2/sites-enabled/000-default.conf
#Listen 808
Listen 80
<IfModule ssl_module>
#Listen 4433
Listen 443
</IfModule>
<IfModule mod_gnutls.c>
#Listen 4433
Listen 443
</IfModule>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
waren noch ports 808 und 4433 angegeben. Die habe ich wie oben geändert in 80 und 443. Danahc habe ich versucht, den apache-server neu zu starten, was fehl schlug. Könnt ihr was damit anfangen?
● apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2021-10-30 19:38:08 CEST; 11s ago
Docs: https://httpd.apache.org/docs/2.4/
Process: 2109 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
Okt 30 19:38:08 raspberrypi-iob systemd[1]: Starting The Apache HTTP Server...
Okt 30 19:38:08 raspberrypi-iob apachectl[2109]: (98)Address already in use: AH00072: make_sock: could not bind to address [::]:443
Okt 30 19:38:08 raspberrypi-iob apachectl[2109]: (98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:443
Okt 30 19:38:08 raspberrypi-iob apachectl[2109]: no listening sockets available, shutting down
Okt 30 19:38:08 raspberrypi-iob apachectl[2109]: AH00015: Unable to open logs
Okt 30 19:38:08 raspberrypi-iob apachectl[2109]: Action 'start' failed.
Okt 30 19:38:08 raspberrypi-iob apachectl[2109]: The Apache error log may have more information.
Okt 30 19:38:08 raspberrypi-iob systemd[1]: apache2.service: Control process exited, code=exited, status=1/FAILURE
Okt 30 19:38:08 raspberrypi-iob systemd[1]: apache2.service: Failed with result 'exit-code'.
Okt 30 19:38:08 raspberrypi-iob systemd[1]: Failed to start The Apache HTTP Server.
