Let's Encrypt - Fehler beim erstellen vom Zertifikat
Guten Abend,
nachdem Nextcloud nun stabil lĂ€uft, möchte ich natĂŒrlich SSL/HTTPS einrichten. Mit folgendem Befehl versuche ich das Zertifikat zu erzeugen: sudo letsencrypt --apache
Danach gebe ich meine DomÀne an und erhalte folgenden Error-Code:
There were too many requests of a given type :: Error creating new cert :: Too many certificates already issued for: spdns.de
Please see the logfiles in /var/log/letsencrypt for more details.
Folgendes Steht in der Datei “letsencrypt.log”:
Traceback (most recent call last):
File “/usr/bin/letsencrypt”, line 9, in
load_entry_point(‘letsencrypt==0.4.1’, ‘console_scripts’, ‘letsencrypt’)()
File “/usr/lib/python2.7/dist-packages/letsencrypt/cli.py”, line 1960, in main
setup_logging(config, _cli_log_handler, logfile=‘letsencrypt.log’)
File “/usr/lib/python2.7/dist-packages/letsencrypt/cli.py”, line 1873, in setup_logging
config, logfile=logfile, fmt=fmt)
File “/usr/lib/python2.7/dist-packages/letsencrypt/cli.py”, line 1844, in setup_log_file_handler
log_file_path, maxBytes=2 ** 20, backupCount=10)
File “/usr/lib/python2.7/logging/handlers.py”, line 117, in init
BaseRotatingHandler.init(self, filename, mode, encoding, delay)
File “/usr/lib/python2.7/logging/handlers.py”, line 64, in init
logging.FileHandler.init(self, filename, mode, encoding, delay)
File “/usr/lib/python2.7/logging/init.py”, line 913, in init
StreamHandler.init(self, self._open())
File “/usr/lib/python2.7/logging/init.py”, line 943, in _open
stream = open(self.baseFilename, self.mode)
IOError: [Errno 13] Permission denied: ‘/var/log/letsencrypt/letsencrypt.log’
Was habe ich falsch gemacht? Vielen Dank fĂŒr Eure Hilfe :smiley:
MfG
ByteJunkie
sudo su
apt-get install git
cd /opt
git clone https://github.com/certbot/certbot
service apache2 stop
cd /opt/certbot/
./certbot-auto certonly --standalone --rsa-key-size 4096 -d domain.tld -d www.domain.tld
service apache2 start
vi /etc/apache2/sites-available/domain.name.conf
<IfModule mod_ssl.c>
    SSLEngine on
    SSLProtocol All -SSLv2 -SSLv3
    SSLCertificateFile /etc/letsencrypt/live/domain.tld/fullchain.pem
    SSLCertificateKeyFile /etc/letsencrypt/live/domain.tld/privkey.pem
</IfModule>
service apache2 restart
HTH :wink:
Danke fĂŒr die Antwort. Allerdings bekomme ich immernoch die selbe Fehlermeldung. Es liegt wahrscheinlich daran, dass ich eine Subdomain habe. Da werde ich mir wohl eine Domain kaufen mĂŒssen, was nicht das Problem ist :wink:
