Error PHP Error: shell_exec() has been disabled for security reasons at /home/clients/2ea9770f460154cb810fe27db3dcd32c/web/nextcloud/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#152
<<closure>>
OC\Log\ErrorHandler::onError(2, "shell_exec( ... s", "/home/clien ... p", 152, { interfaces ... l})
/home/clients/2ea9770f460154cb810fe27db3dcd32c/web/nextcloud/apps/serverinfo/lib/OperatingSystems/DefaultOs.php - line 152:
shell_exec("ip addr sho ... '")
/home/clients/2ea9770f460154cb810fe27db3dcd32c/web/nextcloud/apps/serverinfo/lib/Os.php - line 124:
OCA\ServerInfo\OperatingSystems\DefaultOs->getNetworkInterfaces()
/home/clients/2ea9770f460154cb810fe27db3dcd32c/web/nextcloud/apps/serverinfo/lib/Settings/AdminSettings.php - line 111:
OCA\ServerInfo\Os->getNetworkInterfaces()
/home/clients/2ea9770f460154cb810fe27db3dcd32c/web/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php - line 138:
OCA\ServerInfo\Settings\AdminSettings->getForm()
/home/clients/2ea9770f460154cb810fe27db3dcd32c/web/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php - line 83:
OCA\Settings\Controller\AdminSettingsController->formatSettings([ [ OCA\Serv ... ]])
/home/clients/2ea9770f460154cb810fe27db3dcd32c/web/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php - line 149:
OCA\Settings\Controller\AdminSettingsController->getSettings("serverinfo")
/home/clients/2ea9770f460154cb810fe27db3dcd32c/web/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php - line 68:
OCA\Settings\Controller\AdminSettingsController->getIndexResponse("admin", "serverinfo")
/home/clients/2ea9770f460154cb810fe27db3dcd32c/web/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 218:
OCA\Settings\Controller\AdminSettingsController->index("serverinfo")
/home/clients/2ea9770f460154cb810fe27db3dcd32c/web/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 127:
OC\AppFramework\Http\Dispatcher->executeController(OCA\Settings ... {}, "index")
/home/clients/2ea9770f460154cb810fe27db3dcd32c/web/nextcloud/lib/private/AppFramework/App.php - line 157:
OC\AppFramework\Http\Dispatcher->dispatch(OCA\Settings ... {}, "index")
/home/clients/2ea9770f460154cb810fe27db3dcd32c/web/nextcloud/lib/private/Route/Router.php - line 302:
OC\AppFramework\App::main("OCA\\Settin ... r", "index", OC\AppFramew ... {}, { section: " ... "})
/home/clients/2ea9770f460154cb810fe27db3dcd32c/web/nextcloud/lib/base.php - line 993:
OC\Route\Router->match("/settings/admin/serverinfo")
/home/clients/2ea9770f460154cb810fe27db3dcd32c/web/nextcloud/index.php - line 37:
OC::handleRequest()
