example
longer
example
here
Nextcloud version (eg, 20.0.5): 25.0.1
Operating system and version (eg, Ubuntu 20.04): Ubuntu 22.04
Apache or nginx version (eg, Apache 2.4.25): Nginx
PHP version (eg, 7.4): 8.1
I am setting up LDAP. My configuration comes back working fine. The ldap tables in my db show all the users that are suppose to be there. But when I go to the Users section on the website, I don’t see all of them, maybe a quarter of them.
Is this the first time you’ve seen this error? (Y/N): Yes
- Fill our LDAP configuration
{"reqId":"xIJRfor7zMpRGQTcELTF","level":3,"time":"2022-12-05T19:52:40+00:00","remoteAddr":"74.102.47.226","user":"Admin","app":"PHP","method":"POST","url":"/apps/user_ldap/ajax/wizard.php","message":"ldap_search(): Search: Bad search filter at /var/www/nextcloud/apps/user_ldap/lib/LDAP.php#306","userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0","version":"25.0.1.1","exception":{"Exception":"Error","Message":"ldap_search(): Search: Bad search filter at /var/www/nextcloud/apps/user_ldap/lib/LDAP.php#306","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/user_ldap/lib/LDAP.php","line":208,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"function":"OCA\\User_LDAP\\{closure}","class":"OCA\\User_LDAP\\LDAP","type":"->","args":["*** sensitive parameters replaced ***"]},{"function":"ldap_search","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/LDAP.php","line":306,"function":"call_user_func_array","args":["ldap_search",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","And 4 more entries, set log level to debug to see all entries"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/LDAP.php","line":213,"function":"invokeLDAPMethod","class":"OCA\\User_LDAP\\LDAP","type":"->","args":["*** sensitive parameters replaced ***"]},{"function":"search","class":"OCA\\User_LDAP\\LDAP","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Access.php","line":1060,"function":"call_user_func_array","args":[[{"__class__":"OCA\\User_LDAP\\LDAP"},"*** sensitive parameters replaced ***"],["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Access.php","line":1063,"function":"OCA\\User_LDAP\\{closure}","class":"OCA\\User_LDAP\\Access","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Access.php","line":1121,"function":"invokeLDAPMethod","class":"OCA\\User_LDAP\\Access","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Access.php","line":1221,"function":"executeSearch","class":"OCA\\User_LDAP\\Access","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***",500,"*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Access.php","line":985,"function":"count","class":"OCA\\User_LDAP\\Access","type":"->","args":["*** sensitive parameters replaced ***",["*** sensitive parameters replaced ***"],"*** sensitive parameters replaced ***",1001,"*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Wizard.php","line":113,"function":"countUsers","class":"OCA\\User_LDAP\\Access","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***",1001]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Wizard.php","line":162,"function":"countEntries","class":"OCA\\User_LDAP\\Wizard","type":"->","args":["*** sensitive parameters replaced ***","users"]},{"file":"/var/www/nextcloud/apps/user_ldap/ajax/wizard.php","line":96,"function":"countUsers","class":"OCA\\User_LDAP\\Wizard","type":"->","args":[]},{"file":"/var/www/nextcloud/lib/private/Route/Route.php","line":155,"args":["/var/www/nextcloud/apps/user_ldap/ajax/wizard.php"],"function":"require_once"},{"function":"OC\\Route\\{closure}","class":"OC\\Route\\Route","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":306,"function":"call_user_func","args":[{"__class__":"Closure"},["user_ldap_ajax_wizard"]]},{"file":"/var/www/nextcloud/lib/base.php","line":1047,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/apps/user_ldap/ajax/wizard.php"]},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"xIJRfor7zMpRGQTcELTF","level":3,"time":"2022-12-05T19:52:40+00:00","remoteAddr":"74.102.47.226","user":"Admin","app":"user_ldap","method":"POST","url":"/apps/user_ldap/ajax/wizard.php","message":"Attempt for Paging? 1","userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0","version":"25.0.1.1","data":{"app":"user_ldap"}}
{"reqId":"TD4eYzBtkzgD6IsDM9wX","level":3,"time":"2022-12-05T19:52:42+00:00","remoteAddr":"74.102.47.226","user":"Admin","app":"PHP","method":"POST","url":"/apps/user_ldap/ajax/wizard.php","message":"ldap_search(): Search: Bad search filter at /var/www/nextcloud/apps/user_ldap/lib/LDAP.php#306","userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0","version":"25.0.1.1","exception":{"Exception":"Error","Message":"ldap_search(): Search: Bad search filter at /var/www/nextcloud/apps/user_ldap/lib/LDAP.php#306","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/user_ldap/lib/LDAP.php","line":208,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"function":"OCA\\User_LDAP\\{closure}","class":"OCA\\User_LDAP\\LDAP","type":"->","args":["*** sensitive parameters replaced ***"]},{"function":"ldap_search","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/LDAP.php","line":306,"function":"call_user_func_array","args":["ldap_search",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","And 4 more entries, set log level to debug to see all entries"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/LDAP.php","line":213,"function":"invokeLDAPMethod","class":"OCA\\User_LDAP\\LDAP","type":"->","args":["*** sensitive parameters replaced ***"]},{"function":"search","class":"OCA\\User_LDAP\\LDAP","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Access.php","line":1060,"function":"call_user_func_array","args":[[{"__class__":"OCA\\User_LDAP\\LDAP"},"*** sensitive parameters replaced ***"],["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Access.php","line":1063,"function":"OCA\\User_LDAP\\{closure}","class":"OCA\\User_LDAP\\Access","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Access.php","line":1121,"function":"invokeLDAPMethod","class":"OCA\\User_LDAP\\Access","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Access.php","line":1221,"function":"executeSearch","class":"OCA\\User_LDAP\\Access","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***",500,"*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Access.php","line":985,"function":"count","class":"OCA\\User_LDAP\\Access","type":"->","args":["*** sensitive parameters replaced ***",["*** sensitive parameters replaced ***"],"*** sensitive parameters replaced ***",1001,"*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Wizard.php","line":113,"function":"countUsers","class":"OCA\\User_LDAP\\Access","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***",1001]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Wizard.php","line":162,"function":"countEntries","class":"OCA\\User_LDAP\\Wizard","type":"->","args":["*** sensitive parameters replaced ***","users"]},{"file":"/var/www/nextcloud/apps/user_ldap/ajax/wizard.php","line":96,"function":"countUsers","class":"OCA\\User_LDAP\\Wizard","type":"->","args":[]},{"file":"/var/www/nextcloud/lib/private/Route/Route.php","line":155,"args":["/var/www/nextcloud/apps/user_ldap/ajax/wizard.php"],"function":"require_once"},{"function":"OC\\Route\\{closure}","class":"OC\\Route\\Route","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":306,"function":"call_user_func","args":[{"__class__":"Closure"},["user_ldap_ajax_wizard"]]},{"file":"/var/www/nextcloud/lib/base.php","line":1047,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/apps/user_ldap/ajax/wizard.php"]},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"TD4eYzBtkzgD6IsDM9wX","level":3,"time":"2022-12-05T19:52:42+00:00","remoteAddr":"74.102.47.226","user":"Admin","app":"user_ldap","method":"POST","url":"/apps/user_ldap/ajax/wizard.php","message":"Attempt for Paging? 1","userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0","version":"25.0.1.1","data":{"app":"user_ldap"}}
{"reqId":"ISFqnylSGEvCdbACZFk3","level":3,"time":"2022-12-05T20:50:17+00:00","remoteAddr":"74.102.47.226","user":"--","app":"PHP","method":"POST","url":"/login","message":"Undefined array key 0 at /var/www/nextcloud/apps/user_ldap/lib/User/User.php#240","userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0","version":"25.0.1.1","exception":{"Exception":"Error","Message":"Undefined array key 0 at /var/www/nextcloud/apps/user_ldap/lib/User/User.php#240","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/user_ldap/lib/User/User.php","line":240,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"Undefined array key 0","/var/www/nextcloud/apps/user_ldap/lib/User/User.php",240]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_LDAP.php","line":206,"function":"processAttributes","class":"OCA\\User_LDAP\\User\\User","type":"->","args":[[["06fd3a65-745e-4d01-a1a0-f477f47dd5a8"],["uid=alex.giaquinto,ou=users,dc=taskhuman,dc=com"],["alex.giaquinto"],["cn=engineering,ou=groups,dc=taskhuman,dc=com","cn=infrastructure,ou=groups,dc=taskhuman,dc=com","cn=it,ou=groups,dc=taskhuman,dc=com"],["*** sensitive parameters replaced ***"],"And 2 more entries, set log level to debug to see all entries"]]},{"function":"checkPassword","class":"OCA\\User_LDAP\\User_LDAP","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_Proxy.php","line":108,"function":"call_user_func_array","args":[[{"__class__":"OCA\\User_LDAP\\User_LDAP"},"checkPassword"],["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Proxy.php","line":156,"function":"walkBackends","class":"OCA\\User_LDAP\\User_Proxy","type":"->","args":["*** sensitive parameters replaced ***","checkPassword",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_Proxy.php","line":257,"function":"handleRequest","class":"OCA\\User_LDAP\\Proxy","type":"->","args":["*** sensitive parameters replaced ***","checkPassword",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":267,"function":"checkPassword","class":"OCA\\User_LDAP\\User_Proxy","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/UidLoginCommand.php","line":49,"function":"checkPasswordNoLogging","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php","line":40,"function":"process","class":"OC\\Authentication\\Login\\UidLoginCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/UserDisabledCheckCommand.php","line":58,"function":"processNextOrFinishSuccessfully","class":"OC\\Authentication\\Login\\ALoginCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php","line":40,"function":"process","class":"OC\\Authentication\\Login\\UserDisabledCheckCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/PreLoginHookCommand.php","line":53,"function":"processNextOrFinishSuccessfully","class":"OC\\Authentication\\Login\\ALoginCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/Chain.php","line":108,"function":"process","class":"OC\\Authentication\\Login\\PreLoginHookCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/core/Controller/LoginController.php","line":318,"function":"process","class":"OC\\Authentication\\Login\\Chain","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"tryLogin","class":"OC\\Core\\Controller\\LoginController","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OC\\Core\\Controller\\LoginController"},"tryLogin"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OC\\Core\\Controller\\LoginController"},"tryLogin"]},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OC\\Core\\Controller\\LoginController","tryLogin",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},["core.login.tryLogin"]]},{"file":"/var/www/nextcloud/lib/base.php","line":1047,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/login"]},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"1w5PMy1DwsoEnQj2Z1kg","level":3,"time":"2022-12-05T20:55:36+00:00","remoteAddr":"74.102.47.226","user":"alex.giaquinto@taskhuman.com","app":"PHP","method":"GET","url":"/apps/logreader/poll?lastReqId=ISFqnylSGEvCdbACZFk3","message":"Undefined array key 0 at /var/www/nextcloud/apps/user_ldap/lib/User/User.php#240","userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0","version":"25.0.1.1","exception":{"Exception":"Error","Message":"Undefined array key 0 at /var/www/nextcloud/apps/user_ldap/lib/User/User.php#240","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/user_ldap/lib/User/User.php","line":240,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"Undefined array key 0","/var/www/nextcloud/apps/user_ldap/lib/User/User.php",240]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_LDAP.php","line":206,"function":"processAttributes","class":"OCA\\User_LDAP\\User\\User","type":"->","args":[[["06fd3a65-745e-4d01-a1a0-f477f47dd5a8"],["uid=alex.giaquinto,ou=users,dc=taskhuman,dc=com"],["alex.giaquinto"],["cn=engineering,ou=groups,dc=taskhuman,dc=com","cn=infrastructure,ou=groups,dc=taskhuman,dc=com","cn=it,ou=groups,dc=taskhuman,dc=com"],["*** sensitive parameters replaced ***"],"And 2 more entries, set log level to debug to see all entries"]]},{"function":"checkPassword","class":"OCA\\User_LDAP\\User_LDAP","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_Proxy.php","line":108,"function":"call_user_func_array","args":[[{"__class__":"OCA\\User_LDAP\\User_LDAP"},"checkPassword"],["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Proxy.php","line":156,"function":"walkBackends","class":"OCA\\User_LDAP\\User_Proxy","type":"->","args":["*** sensitive parameters replaced ***","checkPassword",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_Proxy.php","line":257,"function":"handleRequest","class":"OCA\\User_LDAP\\Proxy","type":"->","args":["*** sensitive parameters replaced ***","checkPassword",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":267,"function":"checkPassword","class":"OCA\\User_LDAP\\User_Proxy","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":237,"function":"checkPasswordNoLogging","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":755,"function":"checkPassword","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":795,"function":"checkTokenCredentials","class":"OC\\User\\Session","type":"->","args":[{"__class__":"OC\\Authentication\\Token\\PublicKeyToken","id":10},"*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":257,"function":"validateToken","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":232,"function":"validateSession","class":"OC\\User\\Session","type":"->","args":[]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":269,"function":"getUser","class":"OC\\User\\Session","type":"->","args":[]},{"file":"/var/www/nextcloud/lib/base.php","line":1026,"function":"isLoggedIn","class":"OC\\User\\Session","type":"->","args":[]},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"S0WCgiG24SEra6aePCeR","level":3,"time":"2022-12-05T21:00:44+00:00","remoteAddr":"74.102.47.226","user":"alex.giaquinto@taskhuman.com","app":"PHP","method":"GET","url":"/ocs/v2.php/apps/notifications/api/v2/notifications","message":"Undefined array key 0 at /var/www/nextcloud/apps/user_ldap/lib/User/User.php#240","userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0","version":"25.0.1.1","exception":{"Exception":"Error","Message":"Undefined array key 0 at /var/www/nextcloud/apps/user_ldap/lib/User/User.php#240","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/user_ldap/lib/User/User.php","line":240,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"Undefined array key 0","/var/www/nextcloud/apps/user_ldap/lib/User/User.php",240]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_LDAP.php","line":206,"function":"processAttributes","class":"OCA\\User_LDAP\\User\\User","type":"->","args":[[["06fd3a65-745e-4d01-a1a0-f477f47dd5a8"],["uid=alex.giaquinto,ou=users,dc=taskhuman,dc=com"],["alex.giaquinto"],["cn=engineering,ou=groups,dc=taskhuman,dc=com","cn=infrastructure,ou=groups,dc=taskhuman,dc=com","cn=it,ou=groups,dc=taskhuman,dc=com"],["*** sensitive parameters replaced ***"],"And 2 more entries, set log level to debug to see all entries"]]},{"function":"checkPassword","class":"OCA\\User_LDAP\\User_LDAP","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_Proxy.php","line":108,"function":"call_user_func_array","args":[[{"__class__":"OCA\\User_LDAP\\User_LDAP"},"checkPassword"],["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Proxy.php","line":156,"function":"walkBackends","class":"OCA\\User_LDAP\\User_Proxy","type":"->","args":["*** sensitive parameters replaced ***","checkPassword",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_Proxy.php","line":257,"function":"handleRequest","class":"OCA\\User_LDAP\\Proxy","type":"->","args":["*** sensitive parameters replaced ***","checkPassword",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":267,"function":"checkPassword","class":"OCA\\User_LDAP\\User_Proxy","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":237,"function":"checkPasswordNoLogging","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":755,"function":"checkPassword","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":795,"function":"checkTokenCredentials","class":"OC\\User\\Session","type":"->","args":[{"__class__":"OC\\Authentication\\Token\\PublicKeyToken","id":10},"*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":257,"function":"validateToken","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":232,"function":"validateSession","class":"OC\\User\\Session","type":"->","args":[]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":391,"function":"getUser","class":"OC\\User\\Session","type":"->","args":[]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":123,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"/var/www/nextcloud/ocs/v1.php","line":57,"function":"loadApps","class":"OC_App","type":"::","args":[]},{"file":"/var/www/nextcloud/ocs/v2.php","line":23,"args":["/var/www/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"nC6paq8wpfB80lp0g3Ag","level":3,"time":"2022-12-05T21:00:44+00:00","remoteAddr":"74.102.47.226","user":"alex.giaquinto@taskhuman.com","app":"PHP","method":"PUT","url":"/ocs/v2.php/apps/user_status/api/v1/heartbeat?format=json","message":"Undefined array key 0 at /var/www/nextcloud/apps/user_ldap/lib/User/User.php#240","userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0","version":"25.0.1.1","exception":{"Exception":"Error","Message":"Undefined array key 0 at /var/www/nextcloud/apps/user_ldap/lib/User/User.php#240","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/user_ldap/lib/User/User.php","line":240,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"Undefined array key 0","/var/www/nextcloud/apps/user_ldap/lib/User/User.php",240]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_LDAP.php","line":206,"function":"processAttributes","class":"OCA\\User_LDAP\\User\\User","type":"->","args":[[["06fd3a65-745e-4d01-a1a0-f477f47dd5a8"],["uid=alex.giaquinto,ou=users,dc=taskhuman,dc=com"],["alex.giaquinto"],["cn=engineering,ou=groups,dc=taskhuman,dc=com","cn=infrastructure,ou=groups,dc=taskhuman,dc=com","cn=it,ou=groups,dc=taskhuman,dc=com"],["*** sensitive parameters replaced ***"],"And 2 more entries, set log level to debug to see all entries"]]},{"function":"checkPassword","class":"OCA\\User_LDAP\\User_LDAP","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_Proxy.php","line":108,"function":"call_user_func_array","args":[[{"__class__":"OCA\\User_LDAP\\User_LDAP"},"checkPassword"],["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Proxy.php","line":156,"function":"walkBackends","class":"OCA\\User_LDAP\\User_Proxy","type":"->","args":["*** sensitive parameters replaced ***","checkPassword",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_Proxy.php","line":257,"function":"handleRequest","class":"OCA\\User_LDAP\\Proxy","type":"->","args":["*** sensitive parameters replaced ***","checkPassword",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":267,"function":"checkPassword","class":"OCA\\User_LDAP\\User_Proxy","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":237,"function":"checkPasswordNoLogging","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":755,"function":"checkPassword","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":795,"function":"checkTokenCredentials","class":"OC\\User\\Session","type":"->","args":[{"__class__":"OC\\Authentication\\Token\\PublicKeyToken","id":10},"*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":257,"function":"validateToken","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":232,"function":"validateSession","class":"OC\\User\\Session","type":"->","args":[]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":391,"function":"getUser","class":"OC\\User\\Session","type":"->","args":[]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":123,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"/var/www/nextcloud/ocs/v1.php","line":57,"function":"loadApps","class":"OC_App","type":"::","args":[]},{"file":"/var/www/nextcloud/ocs/v2.php","line":23,"args":["/var/www/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"QMTlhAwvSpxeJm4G1bbW","level":3,"time":"2022-12-05T21:05:55+00:00","remoteAddr":"74.102.47.226","user":"alex.giaquinto@taskhuman.com","app":"PHP","method":"GET","url":"/ocs/v2.php/apps/notifications/api/v2/notifications","message":"Undefined array key 0 at /var/www/nextcloud/apps/user_ldap/lib/User/User.php#240","userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0","version":"25.0.1.1","exception":{"Exception":"Error","Message":"Undefined array key 0 at /var/www/nextcloud/apps/user_ldap/lib/User/User.php#240","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/user_ldap/lib/User/User.php","line":240,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"Undefined array key 0","/var/www/nextcloud/apps/user_ldap/lib/User/User.php",240]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_LDAP.php","line":206,"function":"processAttributes","class":"OCA\\User_LDAP\\User\\User","type":"->","args":[[["06fd3a65-745e-4d01-a1a0-f477f47dd5a8"],["uid=alex.giaquinto,ou=users,dc=taskhuman,dc=com"],["alex.giaquinto"],["cn=engineering,ou=groups,dc=taskhuman,dc=com","cn=infrastructure,ou=groups,dc=taskhuman,dc=com","cn=it,ou=groups,dc=taskhuman,dc=com"],["*** sensitive parameters replaced ***"],"And 2 more entries, set log level to debug to see all entries"]]},{"function":"checkPassword","class":"OCA\\User_LDAP\\User_LDAP","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_Proxy.php","line":108,"function":"call_user_func_array","args":[[{"__class__":"OCA\\User_LDAP\\User_LDAP"},"checkPassword"],["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Proxy.php","line":156,"function":"walkBackends","class":"OCA\\User_LDAP\\User_Proxy","type":"->","args":["*** sensitive parameters replaced ***","checkPassword",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_Proxy.php","line":257,"function":"handleRequest","class":"OCA\\User_LDAP\\Proxy","type":"->","args":["*** sensitive parameters replaced ***","checkPassword",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":267,"function":"checkPassword","class":"OCA\\User_LDAP\\User_Proxy","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":237,"function":"checkPasswordNoLogging","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":755,"function":"checkPassword","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":795,"function":"checkTokenCredentials","class":"OC\\User\\Session","type":"->","args":[{"__class__":"OC\\Authentication\\Token\\PublicKeyToken","id":10},"*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":257,"function":"validateToken","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":232,"function":"validateSession","class":"OC\\User\\Session","type":"->","args":[]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":391,"function":"getUser","class":"OC\\User\\Session","type":"->","args":[]},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":123,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"/var/www/nextcloud/ocs/v1.php","line":57,"function":"loadApps","class":"OC_App","type":"::","args":[]},{"file":"/var/www/nextcloud/ocs/v2.php","line":23,"args":["/var/www/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"PJPAEVU01PXXAieJHxbX","level":3,"time":"2022-12-05T21:05:57+00:00","remoteAddr":"74.102.47.226","user":"alex.giaquinto@taskhuman.com","app":"PHP","method":"GET","url":"/apps/logreader/poll?lastReqId=nC6paq8wpfB80lp0g3Ag","message":"Undefined array key 0 at /var/www/nextcloud/apps/user_ldap/lib/User/User.php#240","userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0","version":"25.0.1.1","exception":{"Exception":"Error","Message":"Undefined array key 0 at /var/www/nextcloud/apps/user_ldap/lib/User/User.php#240","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/user_ldap/lib/User/User.php","line":240,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"Undefined array key 0","/var/www/nextcloud/apps/user_ldap/lib/User/User.php",240]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_LDAP.php","line":206,"function":"processAttributes","class":"OCA\\User_LDAP\\User\\User","type":"->","args":[[["06fd3a65-745e-4d01-a1a0-f477f47dd5a8"],["uid=alex.giaquinto,ou=users,dc=taskhuman,dc=com"],["alex.giaquinto"],["cn=engineering,ou=groups,dc=taskhuman,dc=com","cn=infrastructure,ou=groups,dc=taskhuman,dc=com","cn=it,ou=groups,dc=taskhuman,dc=com"],["*** sensitive parameters replaced ***"],"And 2 more entries, set log level to debug to see all entries"]]},{"function":"checkPassword","class":"OCA\\User_LDAP\\User_LDAP","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_Proxy.php","line":108,"function":"call_user_func_array","args":[[{"__class__":"OCA\\User_LDAP\\User_LDAP"},"checkPassword"],["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Proxy.php","line":156,"function":"walkBackends","class":"OCA\\User_LDAP\\User_Proxy","type":"->","args":["*** sensitive parameters replaced ***","checkPassword",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_Proxy.php","line":257,"function":"handleRequest","class":"OCA\\User_LDAP\\Proxy","type":"->","args":["*** sensitive parameters replaced ***","checkPassword",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":267,"function":"checkPassword","class":"OCA\\User_LDAP\\User_Proxy","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":237,"function":"checkPasswordNoLogging","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":755,"function":"checkPassword","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":795,"function":"checkTokenCredentials","class":"OC\\User\\Session","type":"->","args":[{"__class__":"OC\\Authentication\\Token\\PublicKeyToken","id":10},"*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":257,"function":"validateToken","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":232,"function":"validateSession","class":"OC\\User\\Session","type":"->","args":[]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":269,"function":"getUser","class":"OC\\User\\Session","type":"->","args":[]},{"file":"/var/www/nextcloud/lib/base.php","line":1026,"function":"isLoggedIn","class":"OC\\User\\Session","type":"->","args":[]},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"tFaR66S310j8Q5NltwkW","level":3,"time":"2022-12-05T21:11:05+00:00","remoteAddr":"74.102.47.226","user":"alex.giaquinto@taskhuman.com","app":"PHP","method":"GET","url":"/apps/logreader/poll?lastReqId=PJPAEVU01PXXAieJHxbX","message":"Undefined array key 0 at /var/www/nextcloud/apps/user_ldap/lib/User/User.php#240","userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0","version":"25.0.1.1","exception":{"Exception":"Error","Message":"Undefined array key 0 at /var/www/nextcloud/apps/user_ldap/lib/User/User.php#240","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/user_ldap/lib/User/User.php","line":240,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"Undefined array key 0","/var/www/nextcloud/apps/user_ldap/lib/User/User.php",240]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_LDAP.php","line":206,"function":"processAttributes","class":"OCA\\User_LDAP\\User\\User","type":"->","args":[[["06fd3a65-745e-4d01-a1a0-f477f47dd5a8"],["uid=alex.giaquinto,ou=users,dc=taskhuman,dc=com"],["alex.giaquinto"],["cn=engineering,ou=groups,dc=taskhuman,dc=com","cn=infrastructure,ou=groups,dc=taskhuman,dc=com","cn=it,ou=groups,dc=taskhuman,dc=com"],["*** sensitive parameters replaced ***"],"And 2 more entries, set log level to debug to see all entries"]]},{"function":"checkPassword","class":"OCA\\User_LDAP\\User_LDAP","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_Proxy.php","line":108,"function":"call_user_func_array","args":[[{"__class__":"OCA\\User_LDAP\\User_LDAP"},"checkPassword"],["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/Proxy.php","line":156,"function":"walkBackends","class":"OCA\\User_LDAP\\User_Proxy","type":"->","args":["*** sensitive parameters replaced ***","checkPassword",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/apps/user_ldap/lib/User_Proxy.php","line":257,"function":"handleRequest","class":"OCA\\User_LDAP\\Proxy","type":"->","args":["*** sensitive parameters replaced ***","checkPassword",["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]]},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":267,"function":"checkPassword","class":"OCA\\User_LDAP\\User_Proxy","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":237,"function":"checkPasswordNoLogging","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":755,"function":"checkPassword","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":795,"function":"checkTokenCredentials","class":"OC\\User\\Session","type":"->","args":[{"__class__":"OC\\Authentication\\Token\\PublicKeyToken","id":10},"*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":257,"function":"validateToken","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":232,"function":"validateSession","class":"OC\\User\\Session","type":"->","args":[]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":269,"function":"getUser","class":"OC\\User\\Session","type":"->","args":[]},{"file":"/var/www/nextcloud/lib/base.php","line":1026,"function":"isLoggedIn","class":"OC\\User\\Session","type":"->","args":[]},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
'instanceid' => 'SECRET',
'passwordsalt' => 'SECRET',
'secret' => 'SECRET',
0 => 'SECRET',
'memcache.locking' => '\OC\Memcache\Redis',
'memcache.local' => '\OC\Memcache\Redis',
'memcache.distributed' => '\OC\Memcache\Redis',
'redis' => [
'host' => 'localhost',
'port' => 6379,
'timeout' => 0.0,
'datadirectory' => '/opt/nextcloud-data',
'logfile' => '/var/www/nextcloud/nextcloud.log',
'dbtype' => 'pgsql',
'version' => '25.0.1.1',
'overwrite.cli.url' => 'SECRET',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:5432',
'dbuser' => 'nextcloud_user',
'dbpassword' => 'SECRET',
'default_phone_region' => 'SECRET',
'skeletondirectory' => '',
[error] 97116#97116: *590 access forbidden by rule, client: , server: , request: "GET /.well-known/webfinger HTTP/2.0", host:
[error] 97116#97116: *590 access forbidden by rule, client: server: request: "GET /.well-known/nodeinfo HTTP/2.0", host:
PASTE HERE
PASTE HERE
