Hello there,
I’m using nextcloud 20.8 and it’s working perfectly fine, I would like to have it working with my LDAP server. I’m have been trying to connect it to the LDAP server but it’s not working. I’m using sssd for the client connection. The LDAP uses the same port 389, but in order to connect the client has to have the shared key. Is nextcloud able to use sssd method to connect?.
Please let me know if you need anything else.
Regards,
