Hello everyone!
Trying to get Nextcloud 12 up and running right now. Here is what does not seem to work for me:
Nextcloud version (eg, 10.0.2): 12.0.0
Operating system and version (eg, Ubuntu 16.04): Debian 8.8
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.10
PHP version (eg, 5.6): 7.0
Is this the first time you’ve seen this error?: yes
Can you reliably replicate it? (If so, please outline steps):
I successfully configured LDAP auth. In my LDAP, there are nested groups, which are all inside the “Users” group. All users have the “gidNumber” attribute, which assigns them to the “Users” group. All groups have the “memberUid” attribute, that can be used for finding out which group the users belong to except “Users”.
Nextcloud only shows the LDAP users to be the members of the “Users”-group, not anything else. When logging in as an LDAP user in the terminal, I can see all the groups the user belongs to just fine.
How can I configure Nextcloud to see group memberships beyond what is specified in the “gidNumber” attribute?
Error PHP ldap_search(): Partial search results returned: Sizelimit exceeded at /var/www/html/nextcloud/apps/user_ldap/lib/LDAP.php#293 2017-06-16T12:37:43+0200
Error PHP ldap_search(): Partial search results returned: Sizelimit exceeded at /var/www/html/nextcloud/apps/user_ldap/lib/LDAP.php#293 2017-06-16T12:27:03+020
