Hello:=)
i would like to install nextcloud 18 (LAN) manually. is set up so far and is currently stuck at the input of the database data. As soon as I enter the data, I get the error “Failed to enable app federatedfilesharing”. I do not have this issue when i install nextcloud on my other servers so i have no idea what is going on there.
document root permissions: www-data:www-data and rwxr-x—
The error in Nginx error log:
2020/05/16 21:44:26 [error] 1760#1760: *37 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.178.23, server: cloud.lan, request: “GET /index.php/csrftoken HTTP/1.1”, upstream: “fastcgi://127.0.0.1:9000”, host: “cloud.lan”, referrer: “https://cloud.lan/index.php”
My Nginx config:
upstream php-handler {
server 127.0.0.1:9000;
server unix:/var/run/php/php7.3-fpm.sock;
server {
listen 80;
server_name cloud.lan;
# enforce https
return 301 https://$server_name$request_uri;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
ssl_certificate /home/pi/certs/example.crt;
ssl_certificate_key /home/pi/certs/example.key;
# Add headers to serve security related headers Before enabling Strict-Transport-Security headers please
#read into this topic first. add_header Strict-Transport-Security "max-age=15768000; includeSubDomains;
#preload;";
add_header X-Robots-Tag none;
# FIX for SAMEORIGIN ERROR
add_header X-Frame-Options “SAMEORIGINâ€;
root /var/www/nextcloud;
add_header Strict-Transport-Security "max-age=15552000; includeSubDomains; preload;";
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
location ^~ /apps/rainloop/app/data {
deny all;
# The following 2 rules are only needed for the user_webfinger app. Uncomment it if you're planning to use
#this app. rewrite ^/.well-known/host-meta /nextcloud/public.php?service=host-meta last; rewrite
#^/.well-known/host-meta.json
# /nextcloud/public.php?service=host-meta-json last;
location /.well-known/acme-challenge { }
location ^~ / {
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json
application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject
application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype
image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard
text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
# Uncomment if your server is build with the ngx_pagespeed module This module is currently not
#supported. pagespeed off;
location / {
rewrite ^ /index.php$request_uri;
deny all;
deny all;
location ~
^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+)\.php(?:$|/) {
include fastcgi_params;
fastcgi_param HTTPS on;
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js and css files Make sure it is BELOW the PHP block
location ~ \.(?:css|js|woff|svg|gif)$ {
add_header Cache-Control "public, max-age=15778463";
# Add headers to serve security related headers (It is intended to have those duplicated to the ones
# above) Before enabling Strict-Transport-Security headers please read into this topic first.
# add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;";
access_log off;
location ~ \.(?:png|html|ttf|ico|jpg|jpeg)$ {
# Optional: Don't log access to other assets
access_log off;
