Originally published at: July maintenance updates: Nextcloud Hub 25 Autumn, 26 Winter & 26 Spring - Nextcloud
Please update to a new version to keep your data safe!
If you are using Nextcloud Hub 25 Autumn, Nextcloud Hub 26 Winter or Nextcloud Hub 26 Spring, we strongly recommend you to update to version 32.0.13, 33.0.7, and 34.0.2 respectively. Maintenance updates include important bug fixes, stability and security upgrades. It is a quick and safe process, as always!
About the updates
Maintenance updates include a number of important bug fixes and improvements in all supported Nextcloud Hub versions. You can find the full changelog on our website.
Found an issue? Please report any issues you find in our GitHub repositories.
Updates are available for:
- Nextcloud Hub 25 Autumn (version 32.0.13)
- Nextcloud Hub 26 Winter (version 33.0.7)
- Nextcloud Hub 26 Spring (version 34.0.2)
Nextcloud Hub 26 Spring: Built together, designed for the future
Discover our latest release, Nextcloud Hub 26 Winter! Watch the release presentation on YouTube and PeerTube, and read the release blog.
What’s new:
- Refined design, optimized performance
- Empowering developers with an open platform
- Your choice: Nextcloud Office powered by Collabora or Euro-Office
- Delegate calendars, meetings and mail boxes for better collaboration
- Gantt charts, dependencies & more in Nextcloud Deck
- More agency: let the Assistant work for you across files, emails, forms, and more
- Pexip, Matrix, and more updates in integrations
Discover our latest release! Watch the launch of Nextcloud Hub 26 Spring on your favourite platform and read the release blog.
Always keep your server up to date!
Nextcloud’s minor releases primarily focus on addressing security vulnerabilities and functionality bugs, avoiding major system overhauls that could jeopardize user data. Keeping your server up to date is vital, and our approach to testing and validation ensures that upgrading to minor releases is generally smooth and reliable.
For mission-critical Nextcloud systems in enterprise settings, consider switching to Nextcloud Enterprise. The tier provides you with ultimate deployment confidence: direct access to the Nextcloud engineering team, full assistance throughout deployment and integration, and peace of mind for system administrators. If you’re responsible for maintaining Nextcloud in your setting, this option may be the ideal solution for you.
