Nextcloud version (eg, 18.0.2): 20.0.4
Operating system and version (eg, Ubuntu 20.04): Docker Image
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.38
PHP version (eg, 7.1): 7.4.13
Cron job is not running (properly)?!
The following error is shown:
- It was not possible to execute the cron job via CLI. The following technical errors have appeared:
- Your data directory is invalid Ensure there is a file called “.ocdata” in the root of the data directory.
- Last background job execution ran 23 hours ago. Something seems wrong. Check the background job settings
I tried/checked/verified the following:
- The
datadirectory
as well as the.ocdata
file are accessible by thewww-data
user. The above mentioned error that there is no “.ocdata” is complete nonsense. It is also possible to browse the files in the NC UI. - I am using external SMB storages and I assume that this is somehow related, but I haven’t seen any errors that would point me into the right direction.
- I did run a
occ files:scan --all
- no errors were shown but the issue is still there. - I cannot change the background job setting from “Cron” to “Ajax” or “Webcron”, neither via the GUI nor via
occ
(even after renaming/cron.sh
and.../cron.php
(as suggested somewhere else). - I executed
php -f cron.php
(as www-data) manually, it returned quite immediately - no error or any output whatsoever. - I tried to mount the data directory under
/var/www/oc_data
(as suggested here: [solved] Trying to restore nextcloud, Your data directory is invalid - #2 by iGormilhit) but still no luck…
I’m really running out of ideas how to further troubleshoot this issue.
