Hello I’m new with nextCloud and have configured for the first time.
In the first step I configured without 2 factor authentification.
Nextcloud works fine and on my android smartphone with the DAVx5 App I can sync my calendar successfull.
Then I have seen that nextCloud has got the option for 2 factor authetification.
I have configured and the login works fine with 2 factor authentification (FreeOTP App creates the code).
But since I have activated 2 factor authentification the App for CalDav (DAVx5) show me an login error. If I disable 2 factor authentification DAVx5 works fine again.
How to use 2 factor authentification for nextCloud login AND DAVx5 for calender sync?
Anybody has got a solution?
kind regards,
Joe
