example
longer
example
here
Nextcloud version (eg, 18.0.2):
Operating system and version (eg, Ubuntu 20.04):
PHP version (eg, 7.1):
Hello
I am running nextcloud pi
I am not a big linux guy
I can do some things
I have an issue with my db
and I do a scan and it is ok
The only way it works is innodb_force_recovery = 2
I need to do this every time I start Nextcloud Pi. Also
letsencrypt does not seem to be updating the certs properly.
I also cannot do an upgrade
I get errors when I do
I believe I need an updated source.list
I would appreciate any help
No
- Start nextcloud
- on the terminal use apt-get update and apt-get upgade.
PASTE HERE
PASTE HERE
PASTE HERE
