example
longer
example
here
Nextcloud version (eg, 20.0.5): 25.0.0.18
Operating system and version (eg, Ubuntu 20.04): nethserver 7.9.2009
Apache or nginx version (eg, Apache 2.4.25): 2.4.6
PHP version (eg, 7.4): 8.0.23
Downgrading is not supported and is likely to cause unpredictable issues (from 25.0.0.18 to 24.0.7.1)
- Upgraded to 25.0.0.18
- Haven’t touched upgrade since the upgrade
- Auto updater is on
Cant access anything, OCC not working just throwing the Downgrading is not supported and is likely to cause unpredictable issues (from 25.0.0.18 to 24.0.7.1)
'instanceid' => 'REDACTED',
'passwordsalt' => 'REDACTED',
'secret' => 'REDACTED',
'datadirectory' => '/mydata/DATA/',
'dbtype' => 'sqlite3',
'version' => '25.0.0.18',
'overwrite.cli.url' => 'https://myip/nextcloud',
'logfile' => '/var/lib/nethserver/nextcloud/nextcloud.log',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => '',
'mail_from_address' => 'no-reply',
'mail_domain' => 'homenet.dom',
'mail_smtphost' => 'localhost',
'mail_smtpport' => '25',
'loglevel' => 2,
'theme' => '',
'app_install_overwrite' =>
0 => 'dicomviewer',
'dbhost' => 'localhost:/run/rh-mariadb105-mariadb/nextcloud-mysql.sock',
'updatechecker' => false,
'check_for_working_wellknown_setup' => false,
0 => 'localhost',
1 => 'mydomain',
2 => 'my ip',
PASTE HERE
PASTE HERE
{"reqId":"Y2kXYgT7LDlsrA7A7fwlrQAAAEc","level":4,"time":"2022-11-07T14:34:10+00:00","remoteAddr":"myIP","user":"PK1","app":"webdav","method":"PROPFIND","url":"/nextcloud/remote.php/dav/files/PK1/","message":"OCP\\HintException: Downgrading is not supported and is likely to cause unpredictable issues (from 25.0.0.18 to 24.0.7.1)","userAgent":"Mozilla/5.0 (Windows) mirall/3.4.0stable-Win64 (build 20211129) (Nextcloud, windows-10.0.19044 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"25.0.0.18","exception":{"Exception":"Sabre\\DAV\\Exception\\ServiceUnavailable","Message":"OCP\\HintException: Downgrading is not supported and is likely to cause unpredictable issues (from 25.0.0.18 to 24.0.7.1)","Code":0,"Trace":[{"file":"/usr/share/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"{closure}","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":456,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/usr/share/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/usr/share/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/usr/share/nextcloud/remote.php","line":76,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/usr/share/nextcloud/remote.php","line":172,"function":"handleException"}],"File":"/usr/share/nextcloud/remote.php","Line":74,"CustomMessage":"--"}}
