Initially I had Nextcloud (version 15) running happily as a docker container, but upgrade has been a headache. In my docker-compose file I had set
image: nextcloud:15-apache
and mindful of upgrading one version at a time, I tried changing that to nextcloud:16-apache
, but the resulting container refused to start. I tried a few other things, and discovered that the database version was 20.0.1.1, and the nextcloud version was something else. So I threw caution to the winds and tried
image:nextcloud:20.0.1-apache
which has given me a container that starts, but which I can’t access with a browser. Attempting to log in produces
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
I have tried to enter the docker container and see what I can do with occ
. The status is:
Nextcloud or one of the apps require upgrade - only a limited number of commands are available
You may use your browser or the occ upgrade command to do the upgrade
- installed: true
- version: 20.0.1.1
- versionstring: 20.0.1
- edition:
However, for example the command php occ upgrade
produces:
Exception: Updates between multiple major versions and downgrades are unsupported.
Update failed
I’m not quite sure how to recover from this. Given that all my data is stored external to the container, I could possibly completely remove it and build a new container from scratch (using image: nextcloud:latest
But can I somehow fix the current container? Many thanks!
