Salutes NC fellows!
Today I’ve been trying to mount my files directory through webDAV but got faced an annoying issue. Reading this documentation and doing the step-by-step, I could mount my directory properly during the configuration, but there was a problem when the systemd tried to automount the directory during the boot such that the system couldn’t start.
Here is the boot logging related to the problem:
Mar 03 23:15:05 pc mount.davfs[531]: davfs2 1.5.2
Mar 03 23:15:05 pc mount[528]: Please enter the username to authenticate with server
Mar 03 23:15:05 pc mount[528]: localhost/remote.php/dav/files/evandro/ or hit enter for none.
Mar 03 23:15:05 pc mount[528]: Username:
Mar 03 23:15:05 pc systemd[1]: home-evandro-nextcloud.mount: Mount process exited, code=exited status=255
Mar 03 23:15:05 pc systemd[1]: Failed to mount /home/evandro/nextcloud.
– Subject: Unit home-evandro-nextcloud.mount has failed
– Defined-By: systemd
– Support: systemd-devel Info Page– Unit home-evandro-nextcloud.mount has failed.
– The result is failed.
Mar 03 23:15:05 pc systemd[1]: Dependency failed for Local File Systems.
– Subject: Unit local-fs.target has failed
– Support: systemd-devel Info Page– Unit local-fs.target has failed.
– The result is dependency.
Mar 03 23:15:05 pc systemd[1]: Dependency failed for Clean up any mess left by 0dns-up.
– Subject: Unit dns-clean.service has failed
– Support: systemd-devel Info Page– Unit dns-clean.service has failed.
Mar 03 23:15:05 pc systemd[1]: dns-clean.service: Job dns-clean.service/start failed with result ‘dependency’.
Mar 03 23:15:05 pc systemd[1]: local-fs.target: Job local-fs.target/start failed with result ‘dependency’.
Mar 03 23:15:05 pc systemd[1]: local-fs.target: Triggering OnFailure= dependencies.
Mar 03 23:15:05 pc systemd[1]: home-evandro-nextcloud.mount: Unit entered failed state.
It looks like the system is asking for authentication, but, as stated in documentation, wouldn’t this be done automatically as specified at the ~/.davfs2/secrets config file?
Using:
Nextcloud 11.0.1
Ubuntu 16.04.02
Every help is welcome, a lot =)
