Issue with nc-static-IP on NextcloudPi v1.55.3
Hello everyone,
I am experiencing an issue with NextcloudPi version v1.55.3. When trying to change the Static IP using nc-static-IP, the configuration does not apply. After running the command and rebooting, the IP remains unchanged.
Has anyone else encountered this problem? Is there a workaround or a known fix for this issue?
Thanks in advance for your help!
Imho it is a question of the underlaying os, how network is managed. Keep in mind fresh ncp setups (1.55.3) are armbian based. There armbian-config or netplan may do the trick.
