I am trying to setup Haproxy container. Below is my haproxy config
global
log 127.0.0.1 local0
log 127.0.0.1 local1 notice
chroot /var/lib/haproxy
user haproxy
group haproxy
# daemon
defaults
mode http
timeout connect 5000ms
timeout client 50000ms
timeout server 50000ms
frontend http-in
bind *:80
acl has_nextcloud path_beg /nextcloud
acl has_grafana path_beg /grafana
use_backend grafana if has_grafana
use_backend nextcloud if has_nextcloud
default_backend nextcloud
backend grafana
reqrep ^([^\ ]*\ /)grafana[/]?(.*) \1\2
server grafana grafana:3000 check
backend nextcloud
reqrep ^([^\ ]*\ /)nextcould[/]?(.*) \1\2
server nextcloud nextcloud:80 check
haproxy is set to run on a docker container as well as nextcloud. But when I start the haproxy container, I am getting the error below
[ALERT] 115/161301 (15) : parsing [/etc/haproxy/haproxy.cfg:38] : Unknown host in ‘nextcloud:80’
[ALERT] 115/161301 (15) : Error(s) found in configuration file : /etc/haproxy/haproxy.cfg
[ALERT] 115/161301 (15) : Fatal errors found in configuration.
other containers have no issue. I have tried 3 different Haproxy images and I am getting the same error, I assume this is an issue with the nextcloud docker image which can’t be reached with http://nextcloud. Anyone here to assist or advise what the issue could be?
