Background
Server2 was live for 3 years and then in the process of updating from an older version the database became corrupt. I migrated everything to Server1 and completely rebuilt Server2. I’m looking to have federated servers in 3 regions with shares so that files are publicly available across those 3 regions. My use is too small to consider enterprise as this is just for some filesharing for a game.
Nextcloud version: 22.0.0
Operating system and version: Ubuntu 20.04
Apache or nginx version: Apache 2.4..41
PHP version: 7.4
Server1 can add Server2 but Server2 cannot add Server1 as a Trusted server. When attempting to create federated shares via username@domain.com I can create it from Server1 to Server2. But, not the other direction.
The share that is created shows up and I can accepted it. But if I try to view the contents I get an error:
File not found
The document could not be found on the server. Maybe the share was deleted or has expired?
Link:https://server1.domain.com/remote.php/webdav/filename
Is this the first time you’ve seen this error?: Yes
- Created 2 servers
- Add each as a trusted server.
- Attempt to create a federated share.
Server1 Admin Logs
InvalidArgumentException: Invalid Federated Cloud ID
OC\HintException: No server to federate with found
Server2 Admin Logs
OCP\Files\StorageNotAvailableException: Sabre\HTTP\ClientException: SSL certificate problem: unable to get local issuer certificate
Could not detect any host in subdomain.domain.net/status.php
CONFIG.PHP Server 1
'instanceid' => 'XXXXXXXXXXX',
'passwordsalt' => 'XXXXXXXXXXXXX',
'secret' => 'XXXXXXXXXXX',
0 => 'primary1.domain.net',
1 => 'primary2.domain.com',
2 => 'localhost',
'version' => '22.0.0.11',
'overwrite.cli.url' => 'https://primary1.domain.net',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'user',
'dbpassword' => 'password',
CONFIG.PHP Server 2
'instanceid' => 'XXXXXXXXX',
'passwordsalt' => 'XXXXXXXXXXX',
'secret' => 'XXXXXXXXXXXXX',
0 => 'primary2.domain.com',
1 => 'secondary2.domain.com',
2 => 'primary1.domain.net',
3 => 'localhost',
'datadirectory' => '/var/www/html/nextcloud/nextcloud/data',
'overwrite.cli.url' => 'https://primary.domain.com',
'dbuser' => 'user',
'app_install_overwrite' =>
0 => 'occweb',
SERVER1 Apache Log
[Wed Jul 28 06:38:33.301418 2021] [access_compat:error] [pid 91911] [client MyIP:19356] AH01797: client denied by server configuration: /var/www/nextcloud/data/.ocdata
SERVER2 Apache Log
[Tue Jul 27 17:52:24.280521 2021] [access_compat:error] [pid 16559] [client RandomPublicIP:40374] AH01797: client denied by server configuration: /var/www/html/nextcloud/nextcloud/config/getuser
[Wed Jul 28 00:40:34.182107 2021] [access_compat:error] [pid 10158] [client MyIP:19446] AH01797: client denied by server configuration: /var/www/html/nextcloud/nextcloud/data/.ocdata
