Dear all,
I experienced an issue with collabora. Files cannot be saved due to some issue.
I am currently running the following setup:
Nextcloud: 18.0.4
Collabora App: 3.6.0
PHP: 7.3.18
Please find the logfiles from docker below:
wsd-00008-00116 2020-05-18 17:40:03.719050 [ docbroker_00a ] ERR Unexpected response to WOPI::PutFile : 500Cannot save file to WOPI storage uri [https://cloud.myhomepage.com/index.php/apps/richdocuments/wopi/files/493499_ocbdyjm76any/contents?access_token=gaEND3DSTTgtSh2NXHFlfplFNkYFC2l6&access_token_ttl=0]. Error: | wsd/Storage.cpp:1145 wsd-00008-00116 2020-05-18 17:40:03.720776 [ docbroker_00a ] ERR Failed to save docKey [/index.php/apps/richdocuments/wopi/files/493499_ocbdyjm76any] to URI [https://cloud. myhomepage.com/index.php/apps/richdocuments/wopi/files/493499_ocbdyjm76any?access_token=gaEND3DSTTgtSh2NXHFlfplFNkYFC2l6&access_token_ttl=0]. Notifying client.| wsd/DocumentBroker.cpp:1106 wsd-00008-00116 2020-05-18 17:40:04.404433 [ docbroker_00a ] ERR Unexpected response to WOPI::PutFile : 500Cannot save file to WOPI storage uri [https://cloud. myhomepage.com/index.php/apps/richdocuments/wopi/files/493499_ocbdyjm76any/contents?access_token=gaEND3DSTTgtSh2NXHFlfplFNkYFC2l6&access_token_ttl=0]. Error: | wsd/Storage.cpp:1145 wsd-00008-00116 2020-05-18 17:40:04.406049 [ docbroker_00a ] ERR Failed to save docKey [/index.php/apps/richdocuments/wopi/files/493499_ocbdyjm76any] to URI [https://cloud. myhomepage.com/index.php/apps/richdocuments/wopi/files/493499_ocbdyjm76any?access_token=gaEND3DSTTgtSh2NXHFlfplFNkYFC2l6&access_token_ttl=0]. Notifying client.| wsd/DocumentBroker.cpp:1106
Can anyone help?
