example
longer
example
here
Note: I can’t access some things because I’m on a shared hosting.
Nextcloud version (eg, 12.0.2): 15
Operating system and version (eg, Ubuntu 17.04): Unknown
Apache or nginx version (eg, Apache 2.4.25): Apache2, but exact version is unknown
PHP version (eg, 7.1): 7.2
Is this the first time you’ve seen this error? (Y/N): Yes
- Upload any file, it doesn’t seem like file size matters
The output of your Nextcloud log in Admin > Logging: None, there are no errors about the upload.
'instanceid' => 'EDITED',
'passwordsalt' => 'EDITED',
'secret' => 'EDITED',
0 => 'cloud.coderclub.nl',
'datadirectory' => '/home/u42113p46235/domains/coderclub.nl/public_html/cloud/data',
'version' => '15.0.5.3',
'overwrite.cli.url' => 'https://cloud.coderclub.nl',
'dbname' => 'u42113p46235_cloud',
'dbhost' => 'localhost:3306',
'dbuser' => 'u42113p46235_cloud',
'dbpassword' => 'EDITED',
'updater.secret' => 'EDITED',
'theme' => '',
'loglevel' => 2,
'redis' => [
'host' => 'EDITED',
'port' => EDITED,
'timeout' => 0.0,
'password' => 'EDITED',
: Can’t access these logs
