Nextcloud version: Nextcloud Hub 3 (25.0.3)
Operating system and version: ‘Ubuntu 22.04.1 LTS Apache or nginx version:
Apache/2.4.41 (Ubuntu) PHP version:
PHP 8.1.2-1ubuntu2.9 (cli)’
Hi, I have an issue creating document from inside Nextcloud. As far as I can see, there are no logs in gui log. What other logs are there to check?
Screenshot where I can’t create documents. No error pop up nor in GUI Log. It just seems to do nothing.
Update: Its only these four that do not work:
Resolved; due to me moving my data folder, CADViewer showed these errors in the log:
[no app in context] Error: OCP\AppFramework\QueryException: Could not resolve OCA\Cadviewer\AppInfo\WidgetListener! Class “OCA\Cadviewer\AppInfo\WidgetListener” does not exist at <>
- /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php line 133
OC\AppFramework\Utility\SimpleContainer->resolve()
- /var/www/nextcloud/lib/private/ServerContainer.php line 161
OC\AppFramework\Utility\SimpleContainer->query()
- /var/www/nextcloud/lib/private/EventDispatcher/ServiceEventListener.php line 71
OC\ServerContainer->query()
- /var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php line 251
OC\EventDispatcher\ServiceEventListener->__invoke()
- /var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php line 73
Symfony\Component\EventDispatcher\EventDispatcher->callListeners()
- /var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php line 88
Symfony\Component\EventDispatcher\EventDispatcher->dispatch()
- /var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php line 100
OC\EventDispatcher\EventDispatcher->dispatch()
- /var/www/nextcloud/apps/dashboard/lib/Controller/DashboardController.php line 90
OC\EventDispatcher\EventDispatcher->dispatchTyped()
- /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 225
OCA\Dashboard\Controller\DashboardController->index()
- /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 133
- /var/www/nextcloud/lib/private/AppFramework/App.php line 172
- /var/www/nextcloud/lib/private/Route/Router.php line 298
OC\AppFramework\App::main()
- /var/www/nextcloud/lib/base.php line 1047
OC\Route\Router->match()
- /var/www/nextcloud/index.php line 36
OC::handleRequest()
GET /index.php/apps/dashboard/
from 86.150.170.179 by parnett at 2023-02-17T12:13:58+00:00
After I removed CADViewer isssue was resolved.
