I got a federation share from an owncloud installation.
When I try to add that share to my nextcloud installation, I’m receiving the error message like “…is not an owncloud installation…”.
Isn’t it possible to mount a share from a owncloud installation in nextcloud?
I’m just typing my URL in the field “Add to your owncloud”.
Syntax of URL with https and the path, without index.php.
I checked my config.
Access to my nextcloud installation is working via DynDNS.
When I try to add the federation share now, I’m getting an internal server error.
Not from Apache2, but from my nextcloud installation, telling me, that I have to contact my sysadmin and that I will find more information in the logfiles.
Last I checked with no success.
Either take the link to a shared folder, or if you want to add the store of a user, take the url that is shown in the flie-view (bottom-left): https://example.com/owncloud/remote.php/dav
