Is this help forum build by NextCloud? If yes, which plugin has been used? If not, which App/Software has been used to build this forum?
Thanks.
Thanks.
No, they use Discourse. You can either pay for a manged instance on discourse.org, or host it yourself. The software itself is completely free and open source: GitHub - discourse/discourse: A platform for community discussion. Free, open, simple.
