In the monthly calendar view, each individual event does not have a border - is there an easy way to add one?
I had a quick look at the css files, but I wasn’t sure which option would address this…
Joseph
Joseph
This is clearly the wrong thing to do, but in
nextcloud/apps/calendar/js/public/vendor.js
replace
EventRenderer.prototype.getBorderColor = function (eventDef) {^M
var objs = this.getStylingObjs(eventDef);^M
var i;^M
var val;^M
for (i = 0; i < objs.length && !val; i++) {^M
val = objs[i].eventBorderColor || objs[i].eventColor ||^M
objs[i].borderColor || objs[i].color;^M
}^M
if (!val) {^M
val = this.opt('eventBorderColor') || this.opt('eventColor');^M
}^M
return val;^M
with a return value of your favorite color, for example
return '#828c95';^M
Of course, you have to change this in vendor.min.js for it to actually work…
Joseph
Thanks to tcit on irc:
Install the Custom CSS app, then under Theming add the following to the Custom CSS box:
.fc-day-grid-event {
border-color: #828c95 !important;
