I’ve succesfully installed and configure Nextcloud on my server, using a Digital Ocean’s Space (which is S3 compatible) as my primary storage. I noticed that the actual data gets stored in the Space as a bunch of urn:oid: files, which I assume that are my files encrypted.
Is there any way to disable this encryption? If not, is is possible to decrypt them to read them as the original files?
Here’s my config.php:
'passwordsalt' => 'XXX',
'secret' => 'XXX',
0 => 'myhost.domain',
'datadirectory' => 'myhost-data-folder',
'version' => '17.0.2.1',
'overwrite.cli.url' => 'https://myhost.domain',
'dbname' => 'myhost-dbname',
'dbhost' => 'myhost-dbhost',
'dbuser' => 'myhost-dbuser',
'objectstore' =>
'class' => '\\OC\\Files\\ObjectStore\\S3',
'arguments' =>
'bucket' => 'digital-ocean-space-name',
'autocreate' => true,
'key' => 'digital-ocean-space-key',
'secret' => 'digital-ocean-space-secret',
'hostname' => 'nyc3.digitaloceanspaces.com',
'port' => 443,
'use_ssl' => true,
'region' => 'nyc3',
'use_path_style' => false,
'instanceid' => 'myhost-instanceid',
'dbpassword' => 'myhost-dbpassword',
'ldapIgnoreNamingRules' => false,
'app_install_overwrite' =>
0 => 'ldaporg',
Nextcloud version: 17.0.2
Operating system and version: CentOS 8
Nginx version: 1.14.1
PHP version: 7.2.11-1
