Is there a way for nextcloud to utilize GPU?
when im scrolling through images on my nextcloud app on my phone i can see that the CPU on my server is running at 99%. i have a 1660 gpu in the server, is there anyway for the nextcloud to utilize it instead of the CPU?
No, there isn’t.
It makes no sense, trying to handle a grapical device like a central processing unit.
thanks for that information
You may want to look into the preview generator app and to pre-generate Images thumbnails and previews in order to avoid pegging your CPU during general browsing activities.
Also using the Imaginary container tends to be a bit more efficient.
https://docs.nextcloud.com/server/latest/admin_manual/installation/server_tuning.html#previews
As to using your GPU If you’re using the Memories or machine-learning apps like recognize you can utilize the GPU for Video decoding or machine-learning hardware acceleration. Image resizing is technically possible with the GPU but would take a bit of work to get working for probably little to no performance boost.
Awesome!. Will look into this! Great info
I setup imaginary on docker and added it to my nextcloud config.php file and it seems to be loading the images way faster and offloading the CPU. very cool. could i also use the preview generator app as well?
Yes, imaginary is hooked into Nextcloud’s Preview providers so the preview generator will use that.
