I usually save files I am editing very often, but I don’t want that nextcloud is uploading the file every time I change it. Especially if I am syncing a programming directory there is the problem that everytime I run the complier my files are immediatelly uploaded.
This behavior uses much internet volume and stresses the cloud storage…
So is there a possibility to add a delay (about 30 minutes) between filechange and upload?
Thank you for your answer!
But is this variable not used to specify the frequency of asking the server for changes?
I want to have a delay before uploading a file after changing it…
