NC100
January 9, 2023, 8:07am
#1
Is proc_open required for Nextcloud Talk?
I get this log error twice a day at the exact same time. Talk is working and Mattermost app is not installed.
cron Error: Call to undefined function OCA\Talk\proc_open()
/xxx/apps/spreed/lib/MatterbridgeManager.php - line 725:
OCA\Talk\MatterbridgeManager->runCommand()
/xxx/apps/spreed/lib/MatterbridgeManager.php - line 851:
OCA\Talk\MatterbridgeManager->killZombieBridges()
/xxx/apps/spreed/lib/BackgroundJob/CheckMatterbridges.php - line 66:
OCA\Talk\MatterbridgeManager->stopAllBridges()
/xxx/lib/public/BackgroundJob/Job.php - line 78:
OCA\Talk\BackgroundJob\CheckMatterbridges->run()
/xxx/lib/public/BackgroundJob/TimedJob.php - line 103:
OCP\BackgroundJob\Job->start()
/xxx/lib/public/BackgroundJob/TimedJob.php - line 93:
OCP\BackgroundJob\TimedJob->start()
/xxx/cron.php - line 152:
OCP\BackgroundJob\TimedJob->execute()
Nextcloud 25.0.2
PHP 8.1
Latest app version
NC100
January 10, 2023, 6:23am
#2
A simple question, is proc_open required for Nextcloud Talk or the Mattermost app?
kesselb
January 10, 2023, 10:22am
#3
proc_open is required for Nextcloud Talk.
Only if matterbridge (I think that’s what @NC100 is referring to) is used and for integration tests, but not for the “normal” Talk functionality.
See Use proc_open to run system commands in bridge manager by julien-nc · Pull Request #4746 · nextcloud/spreed · GitHub
NC100
January 10, 2023, 11:04am
#5
Okay, thanks! Isn’t it strange that I get this log error when Matterbridge is not installed?
This should only run if matterbridge is enabled: https://github.com/nextcloud/spreed/blob/c21f3f40ef583bf17f3e312b4f063afc1fb24a41/lib/BackgroundJob/CheckMatterbridges.php#L61
Did you enable matterbridge at some point?
Edit: Ah, no it tries to stop the bridges, that’s why you see this. Hm.
So there was a similar report at Error in logs · Issue #5958 · nextcloud/spreed · GitHub
Besides being annoying, there’s no harm in the error. I would just ignore it. If you feel this needs addressed, you can open a issue at the spreed repo, but the result might be the same as in the issue mentioned above.
NC100
January 17, 2023, 10:55am
#8
Solved it by removing row OCA\Talk\BackgroundJob\CheckMatterbridges from database table oc_jobs
