Is nexcloud multitenancy
hello everyone ,
i wan know if : nexcloud is multitenancy ?
You can use the nextcloud in a federated mode to share Information an Data across mulitaple indipendend instances of NC. For HA it is possible to run the Database in a clustor, same for the storage. So you can run multiple instances behind a load balancer.
A lot of Managed Nextclouds can be purchased in a separate instance and/or on their own hardware. Mostly you can see the different Nextcloud instances in the different Nextcloud names and they are maped to different parts of the internet.
thanks for your replay
thanks for your replay bro
