Hey people,
I’ve migrated my server twice now, on the first time (from Snap to plain webserver) the users on my server who don’t have an avatar picture just have a colour without the first initial.
Is it possible to fix this?
As a side note, how does Nextcloud store avatar pictures? – I’ve tried looking in the Nextcloud folder on my webserver and through the database… still not sure.
Hi bobymcbobs,
the avatars are stored as appdata:
nextcloud=> select path from filecache where name like 'avatar%' and path like '%username%';
With the result you can remove the old generated avatas:
find $NCSERVERROOT/appdata_oc6f59l0az9t/avatar -name generated | while read L; do pushd $(dirname $L); rm -f *.png; popd; done
If you have redis for nc, flush the db with:
redis-cli flushdb
next, let occ rescan the app-data files with:
sudo -u wwwrun php $NCSERVERROOT/occ files:scan-app-data
and finaly logoff, reload with CTRL+F5 and logon
