Hi everyone,
I have a question regarding the capabilities of Nextcloud Forms. I am trying to build a form where the options in one drop-down menu depend on the selection made in a previous drop-down.
My scenario:
The user selects a “Product Group” in the first drop-down.
Based on that selection, the second drop-down (“Product”) should only show the specific products that belong to that group.
Is native support for this kind of “cascading” or “conditional” logic available in the current version of Forms? If not, is there a known workaround (for example, showing/hiding different question blocks based on the first answer)?
Thanks in advance for your help!
