igrokit
1
I try to disable the Help menu item.
What I found is the following: https://portal.nextcloud.com/article/disabling-built-in-help-menu-item-12.html
However, that config.php setting described in there does not work.
I realized that the above URL is from the NextCloud Enterprise version.
Does that mean that the config.php setting will not work?
How else can I remove the Help menu?
Thanks
Dan
NextCloud VM, 20.0.2
kesselb
2
'knowledgebaseenabled' => false,
igrokit
3
So the manual at https://portal.nextcloud.com/article/disabling-built-in-help-menu-item-12.html is wrong?
Unfortunately, setting the entry to false did not work.
I restarted php7.4-fpm and apache2 but it had no effect…
igrokit
4
In the meantime I found that the prolem is eventually related to my installation.
The above setting works perfectly in snap installation (https://github.com/nextcloud/nextcloud-snap), but does not work in a VM installation (https://github.com/nextcloud/vm).
I do not know what the differences are, but it looks like the VM version does not read the config.php file the same way?
