Until some days ago I could start my Nextcloud app on my iPhone X by Face ID. Then some IOS update came (11.3.1) and it does not work anymore. Uninstalling and re-installing the app did not help. Starting the app I am asked to configure my finger print which the iPhone does not have. I need to enter the pin code instead. Any idea what I could do ? Any further info needed ? It is not the end of the world but Face ID is simply more comfortable …
Thank you & kind regards,
Bernhard
