I‘ve set up my nc 24 with 2fa (yubikey) which works great for the webfront.
if i try to connect the mobile ios client the workflow for the connection with the yubikey (nfc with ios) does
not work. the workflow with the yubikey and mobile safari on ios works.
the nc app (current and testflight) on ios does not recognize the key.
Not sure if that is supposed to work. Normally, you connect the client, then authenticate via browser and 2FA and then the client gets a permanent client key to log in. Not sure if you wanted to do this, or if you want to login each time with 2FA…
