Server: new installation of nextcloud-files 11.02 from https://repo.morph027.de/nextcloud on Debian Jessie. PHP 5.6.30
Client: existing Thunderbird 45.8.0 with SOGo 31.0.0 also on Debian Jessie
Used Nextcloud web GUI and Thunderbird address book for testing. Created contact on each; synced to other OK. Renamed contact on each; synced to other OK. Deleted contact on each; synced from Thunderbird to web GUI OK; did not sync from web GUI to Thunderbird (contacts no longer listed in web GUI remained visible in Thunderbird).
Nextcloud debug logging enabled but no messages generated when syncing contacts.
'appcodechecker' => true,
'apps_paths' =>
0 =>
'path' => '/var/www/nextcloud/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/var/www/nextcloud/apps2',
'url' => '/apps2',
'writable' => true,
'appstoreenabled' => true,
'appstore.experimental.enabled' => false,
'appstoreurl' => 'https://api.nextcloud.com/v1',
'cron_log' => true,
'dbhost' => 'localhost',
'dbname' => 'nextcloud',
'dbpassword' => '<redacted>',
'dbuser' => 'oc_admin1',
'enable_previews' => false,
'logtimezone' => 'IST',
'log_type' => 'syslog',
'loglevel' => 0,
'overwrite.cli.url' => 'http://localhost',
'passwordsalt' => '<redacted>',
'secret' => '<redacted>',
0 => 'localhost',
1 => '<redacted>',
'version' => '11.0.2.7',
'instanceid' => 'occg6qorz0er',
