example
longer
example
here
Hello everyone. A disaster has happened I can’t understand what the reason is they don’t open
Administration privileges, Users and groups are not added, there is also no option to select. I’ve been suffering for 3 days, I can’t figure out what the problem is.
Nextcloud version Nextcloud Hub 3 (25.0.3)
Operating system and version (eg, Ubuntu 20.04.5) : Ubuntu 20.04.5
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.41
PHP version (eg, 7.4): PHP 7.4.3
When open Users internal server error
[no app in context] Error: Doctrine\DBAL\Exception\DriverException: An exception occurred while executing a query: SQLSTATE[22021]: Character not in repertoire: 7 ERROR: invalid byte sequence for encoding "UTF8": 0xd1 0x5f at <<closure>>
0. /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php line 1780
Doctrine\DBAL\Driver\API\PostgreSQL\ExceptionConverter->convert()
1. /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php line 1719
Doctrine\DBAL\Connection->handleDriverException()
2. /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php line 1067
Doctrine\DBAL\Connection->convertExceptionDuringQuery()
3. /var/www/nextcloud/lib/private/DB/Connection.php line 261
Doctrine\DBAL\Connection->executeQuery()
4. /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php line 345
OC\DB\Connection->executeQuery()
5. /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php line 281
Doctrine\DBAL\Query\QueryBuilder->execute()
6. /var/www/nextcloud/lib/private/Group/Database.php line 461
OC\DB\QueryBuilder\QueryBuilder->execute()
7. /var/www/nextcloud/lib/private/Group/Database.php line 469
OC\Group\Database->getDisplayName()
8. /var/www/nextcloud/lib/private/Group/Manager.php line 181
OC\Group\Database->getGroupDetails()
9. /var/www/nextcloud/lib/private/Group/Manager.php line 169
OC\Group\Manager->getGroupObject()
10. /var/www/nextcloud/lib/private/Group/Manager.php line 205
OC\Group\Manager->get()
11. /var/www/nextcloud/apps/user_ldap/lib/Access.php line 810
OC\Group\Manager->groupExists()
12. /var/www/nextcloud/apps/user_ldap/lib/Access.php line 837
OCA\User_LDAP\Access->_createAltInternalOwnCloudNameForGroups()
13. /var/www/nextcloud/apps/user_ldap/lib/Access.php line 601
OCA\User_LDAP\Access->createAltInternalOwnCloudName()
14. /var/www/nextcloud/apps/user_ldap/lib/Access.php line 944
OCA\User_LDAP\Access->dn2ocname()
15. <<closure>>
OCA\User_LDAP\Access->OCA\User_LDAP\{closure}("*** sensitive parameters replaced ***")
16. /var/www/nextcloud/apps/user_ldap/lib/Access.php line 949
array_walk()
17. /var/www/nextcloud/apps/user_ldap/lib/Group_LDAP.php line 1132
OCA\User_LDAP\Access->fetchListOfGroups()
18. /var/www/nextcloud/apps/user_ldap/lib/Group_Proxy.php line 265
OCA\User_LDAP\Group_LDAP->getGroups()
19. /var/www/nextcloud/lib/private/Group/Manager.php line 241
OCA\User_LDAP\Group_Proxy->getGroups()
20. /var/www/nextcloud/apps/provisioning_api/lib/Controller/GroupsController.php line 110
OC\Group\Manager->search()
21. /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 225
OCA\Provisioning_API\Controller\GroupsController->getGroupsDetails()
22. /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 133
23. /var/www/nextcloud/lib/private/AppFramework/App.php line 172
24. /var/www/nextcloud/lib/private/Route/Router.php line 298
OC\AppFramework\App::main()
25. /var/www/nextcloud/ocs/v1.php line 63
OC\Route\Router->match()
26. /var/www/nextcloud/ocs/v2.php line 23
require_once("/var/www/nextcloud/ocs/v1.php")
GET /ocs/v2.php/cloud/groups/details
from 10.89.21.45 by webadmin at 2023-02-23T18:24:17+03:00
Exception":">{"reqId":"YyILdJZ1v103ud2dj2sr","level":3,"time":"2023-02-23T16:05:09+03:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"
Error while running background job (class: OCA\\User_LDAP\\Jobs\\UpdateGroups, arguments: )","userAgent":"--","version":"25.0.3.2","
Exception":{"
Exception":">{"reqId":"dXukC1wRBNaXM6ELm3GL","level":3,"time":"2023-02-23T16:32:42+03:00","remoteAddr":"10.89.21.45","user":"webadmin","app":"no app in context","method":"GET","url":"/ocs/v2.php/cloud/groups/details","message":"An exception occurred while executing a query: SQLSTATE[22021]: Character not in repertoire: 7>{"reqId":"4n7CmX2LwFvnoOtseJbz","level":3,"time":"2023-02-23T16:32:58+03:00","remoteAddr":"10.89.21.45","user":"webadmin","app":"PHP","method":"GET","url":"/apps/groupfolders/delegation/groups","message":"Undefined offset: 7 at /var/www/nextcloud/lib/private/AppFramework/Http.php#128","userAgent":"Mozilla/5.>{"reqId":"o9PO7OfLa1heQN6BQxUV","level":3,"time":"2023-02-23T16:32:59+03:00","remoteAddr":"10.89.21.45","user":"webadmin","app":"PHP","method":"GET","url":"/apps/groupfolders/delegation/groups","message":"Undefined offset: 7 at /var/www/nextcloud/lib/private/AppFramework/Http.php#128","userAgent":"Mozilla/5.>{"reqId":"vQKqynVwXxTsFhXHpvi3","level":3,"time":"2023-02-23T16:33:00+03:00","remoteAddr":"10.89.21.45","user":"webadmin","app":"PHP","method":"GET","url":"/apps/groupfolders/delegation/groups","message":"Undefined offset: 7 at /var/www/nextcloud/lib/private/AppFramework/Http.php#128","userAgent":"Mozilla/5.>{"reqId":"bwYqQvPruuoWMhV3nIga","level":3,"time":"2023-02-23T16:33:21+03:00","remoteAddr":"10.89.21.45","user":"webadmin","app":"index","method":"GET","url":"/settings/users","message":"An exception occurred while executing a query: SQLSTATE[22021]: Character not in repertoire: 7 ERROR: invalid byte sequenc>{"reqId":"IHfqezRAQaXXW7v5mtmv","level":3,"time":"2023-02-23T17:10:10+03:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"
Exception":{"
Exception":">
postgre sql log
2023-02-22 11:22:28.600 UTC [1325047] ncadmin@nextcloud_db DETAIL: parameters: $1 = 'E6E919A7-B0C4-4235-9980-17FA67E1E053'
2023-02-22 11:22:28.600 UTC [1325047] ncadmin@nextcloud_db LOG: duration: 0.076 ms execute <unnamed>:
SELECT "owncloud_name"
FROM "oc_ldap_group_mapping"
WHERE "directory_uuid" = $1
2023-02-22 11:22:28.601 UTC [1325047] ncadmin@nextcloud_db LOG: duration: 0.052 ms parse <unnamed>: SELECT "displayname" FROM "oc_groups" WHERE "gid" = $1
2023-02-22 11:22:28.601 UTC [1325047] ncadmin@nextcloud_db LOG: duration: 0.099 ms bind <unnamed>: SELECT "displayname" FROM "oc_groups" WHERE "gid" = $1
2023-02-22 11:22:28.601 UTC [1325047] ncadmin@nextcloud_db DETAIL: parameters: $1 = 'Пользователи системного монитора'
2023-02-22 11:22:28.601 UTC [1325047] ncadmin@nextcloud_db LOG: duration: 0.060 ms execute <unnamed>: SELECT "displayname" FROM "oc_groups" WHERE "gid" = $1
2023-02-22 11:22:28.602 UTC [1325047] ncadmin@nextcloud_db LOG: duration: 0.053 ms parse <unnamed>:
WHERE "owncloud_name" LIKE $1
2023-02-22 11:22:28.602 UTC [1325047] ncadmin@nextcloud_db ERROR: invalid byte sequence for encoding "UTF8": 0xd1 0x5f
2023-02-22 11:22:28.602 UTC [1325047] ncadmin@nextcloud_db STATEMENT:
PASTE HERE
PASTE HERE
