Interner Serverfehler wegen eines Filezugriffs
example
longer
example
here
Nextcloud version (eg, 12.0.2): 14.0.3
Operating system and version (eg, Ubuntu 17.04): Nextcloud Docker Image 14 Apache from Git
Apache or nginx version (eg, Apache 2.4.25): Nextcloud Docker Image 14 Apache from Git
PHP version (eg, 7.1): Nextcloud Docker Image 14 Apache from Git
Der Server konnte die Anfrage nicht fertig stellen.
Sollte dies erneut auftreten, senden Sie bitte die nachfolgenden technischen Einzelheiten an Ihren Server-Administrator.
Weitere Details können im Server-Protokoll gefunden werden.
Technische Details
  • Entfernte Adresse: 5.x.x.x
  • Anfragekennung: J2L8tcfzVV4l93crqxQt
Yes
  1. Login
  2. Navigating in Folders and Groupfolders is fine
  3. Crash if selecting “Users” or “Configuration” from Menu
Can’t reach…
<?php $CONFIG = array ( 'htaccess.RewriteBase' => '/', 'memcache.local' => '\\OC\\Memcache\\APCu', 'apps_paths' => array ( 0 => array ( 'path' => '/var/www/html/apps', 'url' => '/apps', 'writable' => false, ), 1 => array ( 'path' => '/var/www/html/custom_apps', 'url' => '/custom_apps', 'writable' => true, ), ), 'instanceid' => '', 'passwordsalt' => '', 'secret' => '', 'trusted_domains' => array ( 0 => '10.x.x.x', 1 => '', ), 'datadirectory' => '/var/www/html/data', 'dbtype' => 'mysql', 'version' => '14.0.3.0', 'overwrite.cli.url' => 'https://', 'dbname' => 'nextcloud', 'dbhost' => '10.6.1.2:3306', 'dbport' => '', 'dbtableprefix' => 'oc_', 'mysql.utf8mb4' => true, 'dbuser' => 'nextcloud', 'dbpassword' => '', 'installed' => true, 'theme' => '', 'loglevel' => 3, 'maintenance' => false, 'mail_from_address' => '', 'mail_smtpmode' => 'smtp', 'mail_domain' => '', 'mail_smtphost' => '', 'mail_smtpport' => '25', 'skeletondirectory' => '', 'default_language' => 'de', 'defaultapp' => 'files', 'tempdirectory' => '/tmp', 'knowledgebaseenabled' => false, 'allow_user_to_change_display_name' => false, 'trashbin_retention_obligation' => '1,3', 'versions_retention_obligation' => '1,3', 'htaccess.RewriteBase' => '/', ); The output of your Apache/nginx/system log in `/var/log/____`: Nothing unusual, no errors... APPS: Enabled: - accessibility: 1.0.1 - activity: 2.7.0 - cloud_federation_api: 0.0.1 - dav: 1.6.0 - federatedfilesharing: 1.4.0 - files: 1.9.0 - files_pdfviewer: 1.3.2 - files_trashbin: 1.4.1 - files_versions: 1.7.1 - groupfolders: 1.3.3 - logreader: 2.0.0 - lookup_server_connector: 1.2.0 - nextcloud_announcements: 1.3.0 - notifications: 2.2.1 - oauth2: 1.2.1 - password_policy: 1.4.0 - provisioning_api: 1.4.0 - serverinfo: 1.4.0 - support: 1.0.0 - survey_client: 1.2.0 - systemtags: 1.4.0 - theming: 1.5.0 - twofactor_backupcodes: 1.3.1 - updatenotification: 1.4.1 - workflowengine: 1.4.0 Disabled: - admin_audit - comments - encryption - federation - files_automatedtagging - files_external - files_retention - files_sharing - files_texteditor - files_videoplayer - firstrunwizard - gallery - sharebymail - user_external - user_ldap The Nextcloud Installation is a Docker Container made from the official Image (14/Apache) from Github. I can log in and browse the folders and group folders. But if I try to choose the Configuration or User Menu the error is thrown. I can you reach the very long line in the nextcloud.log. The error is "Exception":"OCP\\Files\\NotPermittedException" but I can't see which file. Any hints? Thanks,
Der Fehler in der “nextcloud.log” beginnt mit:
{“reqId”:“qEGyWfHw2Sn2Agr3u7iJ”,“level”:3,“time”:“2018-11-01T12:05:39+00:00”,“remoteAddr”:“5.10.x.x”,“user”:“admin”,“app”:“index”,“method”:“GET”,“url”:"/index.php/settings/users",“message”:{“Exception”:“OCP\Files\NotPermittedException”,“Message”:"",“Code”:0,“Trace”:[{“file”:"/var/www/html/lib/private/Files/SimpleFS/SimpleFile.php",“line”:104,“function”:“putContent”,“class”:“OC\Files\Node\File”,“type”:"->",“args”:[":root {\n\t\t\t\t–icon-confirm-fade-000: url(’/index.php/svg/core/actions/confirm-fade/000?v=2’);–icon-add-000: url(’/index.php/svg/core/actions/add/000?v=1’);–icon-add-fff: url(’/index.php/svg/core/actions/add/fff?v=1’);–icon-address-000: url(’/index.php/svg/core/actions/address/000?v=1’);–icon-address-fff: url(’/index.php/svg/core/actions/address/fff?v=1’);–icon-audio-000: url(’/index.php/svg/core/actions/audio/000?v=2’);–icon-audio-fff: url(’/index.php/svg/core/actions/audio/fff?v=2’);–icon-audio-off-000: url(’/index.php/svg/core/actions/audio-off/000?v=1’);–icon-audio-off-fff: url(’/index.php/svg/core/actions/audio-off/fff?v=1’);–icon-caret-fff: url(’/index.php/svg/core/actions/caret/fff?v=1’);–icon-caret-000: url(’/index.php/svg/core/actions/caret/000?v=1’);–icon-checkmark-000: url(’/index.php/svg/core/actions/checkmark/000?v=1’);–icon-checkmark-fff: url(’/index.php/svg/core/actions/checkmark/fff?v=1’);–icon-checkmark-46ba61: url(’/index.php/svg/core/actions/checkmark/46ba61?v=1’);–icon-clippy-000: url(’/index.php/svg/core/actions/clippy/000?v=2’);–icon-clippy-fff: url(’/index.php/svg/core/actions/clippy/fff?v=2’);–icon-close-000: url(’/index.php/svg/core/actions/close/000?v=1’);–icon-close-fff: url(’/index.php/svg/core/actions/close/fff?v=1’);–icon-comment-000: url(’/index.php/svg/core/actions/comment/000?v=1’);–icon-comment-fff: url(’/index.php/svg/core/actions/comment/fff?v=1’);–icon-confirm-000: url(’/index.php/svg/core/actions/confirm/000?v=2’);–icon-confirm-fff: url(’/index.php/svg/core/actions/confirm/fff?v=2’);–icon-download-000: url(’/index.php/svg/core/actions/download/000?v=1’);–icon-download-fff: url(’/index.php/svg/core/actions/download/fff?v=1’);–icon-delete-000: url(’/index.php/svg/core/actions/delete/000?v=1’);–icon-delete-e9322d: url(’/index.php/svg/core/actions/delete/e9322d?v=1’);–icon-delete-fff: url(’/index.php/svg/core/actions/delete/fff?v=1’);–icon-details-000: url(’/index.php/svg/core/actions/details/000?v=1’);–icon-details-fff: url(’/index.php/svg/core/actions/details/fff?v=1’);–icon-edit-000: url(’/index.php/svg/core/actions/edit/000?v=1’);–icon-edit-fff: url(’/index.php/svg/core/actions/edit/fff?v=1’);–icon-error-000: url(’/index.php/svg/core/actions/error/000?v=1’);–icon-error-fff: url(’/index.php/svg/core/actions/error/fff?v=1’);–icon-error-e9322d: url(’/index.php/svg/core/actions/error/e9322d?v=1’);–icon-external-000: url(’/index.php/svg/core/actions/external/000?v=1’);–icon-external-fff: url(’/index.php/svg/core/actions/external/fff?v=1’);–icon-fullscreen-000: url(’/index.php/svg/core/actions/fullscreen/000?v=1’);–icon-fullscreen-fff: url(’/index.php/svg/core/actions/fullscreen/fff?v=1’);–icon-history-000: url(’/index.php/svg/core/actions/history/000?v=2’);–icon-history-fff: url(’/index.php/svg/core/actions/history/fff?v=2’);–icon-info-000: url(’/index.php/svg/core/actions/info/000?v=1’);–icon-info-fff: url(’/index.php/svg/core/actions/info/fff?v=1’);–icon-logout-000: url(’/index.php/svg/core/actions/logout/000?v=1’);–icon-logout-fff: url(’/index.php/svg/core/actions/logout/fff?v=1’);–icon-mail-000: url(’/index.php/svg/core/actions/mail/000?v=1’);–icon-mail-fff: url(’/index.php/svg/core/actions/mail/fff?v=1’);–icon-menu-000: url(’/index.php/svg/core/actions/menu/000?v=1’);–icon-menu-fff: url(’/index.php/svg/core/actions/menu/fff?v=1’);–icon-more-000: url(’/index.php/svg/core/actions/more/000?v=1’);–icon-more-fff: url(’/index.php/svg/core/actions/more/fff?v=1’);–icon-password-000: url(’/index.php/svg/settings/password/000?v=1’);–icon-password-fff: url(’/index.php/svg/core/actions/password/fff?v=1’);–icon-pause-000: url(’/index.php/svg/core/actions/pause/000?v=1’);–icon-pause-fff: url(’/index.php/svg/core/actions/pause/fff?v=1’);–icon-play-000: url(’/index.php/svg/core/actions/play/000?v=1’);–icon-play-fff: url(’/index.php/svg/core/actions/play/fff?v=1’);–icon-play-add-000: url(’/index.php/svg/core/actions/play-add/000?v=1’);–icon-play-add-fff: url(’/index.php/svg/core/actions/play-add/fff?v=1’);–icon-play-next-000: url(’/index.php/svg/core/actions/play-next/000?v=1’);–icon-play-next-fff: url(’/index.php/svg/core/actions/play-next/fff?v=1’);–icon-play-previous-000: url(’/index.php/svg/core/actions/play-previous/000?v=1’);–icon-play-previous-fff: url(’/index.php/svg/core/actions/play-previous/fff?v=1’);–icon-public-000: url(’/index.php/svg/core/actions/public/000?v=1’);–icon-public-fff: url(’/index.php/svg/core/actions/public/fff?v=1’);–icon-quota-000: url(’/index.php/svg/core/actions/quota/000?v=1’);–icon-quota-fff: url(’/index.php/svg/core/actions/quota/fff?v=1’);–icon-rename-000: url(’/index.php/svg/core/actions/rename/000?v=1’);–icon-rename-fff: url(’/index.php/svg/core/actions/rename/fff?v=1’);–icon-screen-000: url(’/index.php/svg/core/actions/screen/000?v=1’);–icon-screen-fff: url(’/index.php/svg/core/actions/screen/fff?v=1’);–icon-screen-off-000: url(’/index.php/svg/core/actions/screen-off/000?v=1’);–icon-screen-off-fff: url(’/index.php/svg/core/actions/screen-off/fff?v=1’);–icon-search-000: url(’/index.php/svg/core/actions/search/000?v=1’);–icon-search-fff: url(’/index.php/svg/core/actions/search/fff?v=1’);–icon-settings-000: url(’/index.php/svg/core/actions/settings/000?v=1’);–icon-settings-dark-000: url(’/index.php/svg/core/actions/settings-dark/000?v=1’);–icon-settings-dark-fff: url(’/index.php/svg/core/actions/settings-dark/fff?v=1’);–icon-share-000: url(’/index.php/svg/settings/share/000?v=1’);–icon-share-fff: url(’/index.php/svg/core/actions/share/fff?v=1’);–icon-sound-000: url(’/index.php/svg/core/actions/sound/000?v=1’);–icon-sound-fff: url(’/index.php/svg/core/actions/sound/fff?v=1’);–icon-sound-off-000: url(’/index.php/svg/core/actions/sound-off/000?v=1’);–icon-sound-off-fff: url(’/index.php/svg/core/actions/sound-off/fff?v=1’);–icon-star-dark-000: url(’/index.php/svg/core/actions/star-dark/000?v=1’);–icon-star-000: url(’/index.php/svg/core/actions/star/000?v=1’);–icon-star-fff: url(’/index.php/svg/core/actions/star/fff?v=1’);–icon-star-dark-FC0: url(’/index.php/svg/core/actions/star-dark/FC0?v=1’);–icon-tag-000: url(’/index.php/svg/systemtags/tag/000?v=1’);–icon-tag-fff: url(’/index.php/svg/core/actions/tag/fff?v=1’);–icon-timezone-000: url(’/index.php/svg/core/actions/timezone/000?v=1’);–icon-timezone-fff: url(’/index.php/svg/core/actions/timezone/fff?v=1’);–icon-toggle-000: url(’/index.php/svg/core/actions/toggle/000?v=1’);–icon-toggle-fff: url(’/index.php/svg/core/actions/toggle/fff?v=1’);–icon-toggle-background-000: url(’/index.php/svg/core/actions/toggle-background/000?v=1’);–icon-toggle-background-fff: url(’/index.php/svg/core/actions/toggle-background/fff?v=1’);–icon-toggle-pictures-000: url(’/index.php/svg/core/actions/toggle-pictures/000?v=1’);–icon-toggle-pictures-fff: url(’/index.php/svg/core/actions/toggle-pictures/fff?v=1’);–icon-triangle-e-000: url(’/index.php/svg/core/actions/triangle-e/000?v=1’);–icon-triangle-e-fff: url(’/index.php/svg/core/actions/triangle-e/fff?v=1’);–icon-triangle-n-000: url(’/index.php/svg/core/actions/triangle-n/000?v=1’);–icon-triangle-n-fff: url(’/index.php/svg/core/actions/triangle-n/fff?v=1’);–icon-triangle-s-000: url(’/index.php/svg/core/actions/triangle-s/000?v=1’);–icon-triangle-s-fff: url(’/index.php/svg/core/actions/triangle-s/fff?v=1’);–icon-upload-000: url(’/index.php/svg/core/actions/upload/000?v=1’);–icon-upload-fff: url(’/index.php/svg/core/actions/upload/fff?v=1’);–icon-user-000: url(’/index.php/svg/core/actions/user/000?v=1’);–icon-user-fff: url(’/index.php/svg/core/actions/user/fff?v=1’);–icon-group-000: url(’/index.php/svg/core/actions/group/000?v=1’);–icon-group-fff: url(’/index.php/svg/core/actions/group/fff?v=1’);–icon-video-000: url(’/index.php/svg/core/actions/video/000?v=2’);–icon-video-fff: url(’/index.php/svg/core/actions/video/fff?v=2’);–icon-video-off-000: url(’/index.php/svg/core/actions/video-off/000?v=1’);–icon-video-off-fff: url(’/index.php/svg/core/actions/video-off/fff?v=1’);–icon-video-switch-000: url(’/index.php/svg/core/actions/video-switch/000?v=1’);–icon-video-switch-fff: url(’/index.php/svg/core/actions/video-switch/fff?v=1’);–icon-view-close-000: url(’/index.php/svg/core/actions/view-close/000?v=1’);–icon-view-close-fff: url(’/index.php/svg/core/actions/view-close/fff?v=1’);–icon-view-download-000: url(’/index.php/svg/core/actions/view-download/000?v=1’);–icon-view-download-fff: url(’/index.php/svg/core/actions/view-download/fff?v=1’);–icon-arrow-right-000: url(’/index.php/svg/core/actions/arrow-right/000?v=1’);–icon-arrow-right-fff: url(’/index.php/svg/core/actions/arrow-right/fff?v=1’);–icon-view-pause-000: url(’/index.php/svg/core/actions/view-pause/000?v=1’);–icon-view-pause-fff: url(’/index.php/svg/core/actions/view-pause/fff?v=1’);–icon-view-play-000: url(’/index.php/svg/core/actions/view-play/000?v=1’);–icon-view-play-fff: url(’/index.php/svg/core/actions/view-play/fff?v=1’);–icon-arrow-left-000: url(’/index.php/svg/core/actions/arrow-left/000?v=1’);–icon-arrow-left-fff: url(’/index.php/svg/core/actions/arrow-left/fff?v=1’);–icon-disabled-user-000: url(’/index.php/svg/core/actions/disabled-user/000?v=1’);–icon-disabled-user-fff: url(’/index.php/svg/core/actions/disabled-user/fff?v=1’);–icon-disabled-users-000: url(’/index.php/svg/core/actions/disabled-users/000?v=1’);–icon-disabled-users-fff: url(’/index.php/svg/core/actions/disabled-users/fff?v=1’);–icon-user-admin-000: url(’/index.php/svg/core/actions/user-admin/000?v=1’);–icon-user-admin-fff: url(’/index.php/svg/core/actions/user-admin/fff?v=1’);–icon-calendar-fff: url(’/index.php/svg/core/places/calendar/fff?v=1’);–icon-calendar-000: url(’/index.php/svg/core/places/calendar/000?v=1’);–icon-contacts-fff: url(’/index.php/svg/core/places/contacts/fff?v=1’);–icon-contacts-000: url(’/index.php/svg/core/places/contacts/000?v=1’);–icon-files-fff: url(’/index.php/svg/core/places/files/fff?v=1’);–icon-files-000: url(’/index.php/svg/core/categories/files/000?v=1’);–icon-text-000: url(’/index.php/svg/core/filetypes/text/000?v=1’);–icon-folder-000: url(’/index.php/svg/core/filetypes/folder/000?v=1’);–icon-folder-fff: url(’/index.php/svg/core/filetypes/folder/fff?v=1’);–icon-folder-drag-accept-000: url(’/index.php/svg/core/filetypes/folder-drag-accept/000?v=1’);–icon-home-000: url(’/index.php/svg/core/places/home/000?v=1’);–icon-home-fff: url(’/index.php/svg/core/places/home/fff?v=1’);–icon-link-000: url(’/index.php/svg/core/places/link/000?v=1’);–icon-link-fff: url(’/index.php/svg/core/places/link/fff?v=1’);–icon-music-000: url(’/index.php/svg/core/places/music/000?v=1’);–icon-music-fff: url(’/index.php/svg/core/places/music/fff?v=1’);–icon-picture-000: url(’/index.php/svg/core/places/picture/000?v=1’);–icon-picture-fff: url(’/index.php/svg/core/places/picture/fff?v=1’);–icon-desktop-000: url(’/index.php/svg/core/clients/desktop/000?v=1’);–icon-desktop-fff: url(’/index.php/svg/core/clients/desktop/fff?v=1’);–icon-phone-000: url(’/index.php/svg/core/clients/phone/000?v=1’);–icon-phone-fff: url(’/index.php/svg/core/clients/phone/fff?v=1’);–icon-tablet-000: url(’/index.php/svg/core/clients/tablet/000?v=1’);–icon-tablet-fff: url(’/index.php/svg/core/clients/tablet/fff?v=1’);–icon-bundles-000: url(’/index.php/svg/core/categories/bundles/000?v=1’);–icon-social-000: url(’/index.php/svg/core/categories/social/000?v=1’);–icon-office-000: url(’/index.php/svg/core/categories/office/000?v=1’);–icon-auth-000: url(’/index.php/svg/core/categories/auth/000?v=1’);–icon-monitoring-000: url(’/index.php/svg/core/categories/monitoring/000?v=1’);–icon-multimedia-000: url(’/index.php/svg/core/categories/multimedia/000?v=1’);–icon-organization-000: url(’/index.php/svg/core/categories/organization/000?v=1’);–icon-customization-000: url(’/index.php/svg/core/categories/customization/000?v=1’);–icon-integration-000: url(’/index.php/svg/core/categories/integration/000?v=1’);–icon-games-000: url(’/index.php/svg/core/categories/games/000?v=1’);–icon-personal-000: url(’/index.php/svg/settings/personal/000?v=1’);–icon-toggle-filelist-000: url(’/index.php/svg/settings/toggle-filelist/000?v=1’);–icon-change-000: url(’/index.php/svg/settings/change/000?v=1’);–icon-recent-000: url(’/index.php/svg/files/recent/000?v=1’);–icon-unshare-000: url(’/index.php/svg/files/unshare/000?v=1’);\n\t\t\t}"]},{“file”:"/var/www/html/lib/private/Template/IconsCacher.php",“line”:115,“function”:“putContent”,“class”:“OC\Files\SimpleFS\SimpleFile”,“type”:"->",“args”:[":root {\n\t\t\t\t–icon-confirm-fade-000: url(’/index.php/svg/core/actions/confirm-fade/000?v=2’);–icon-add-000: url(’/index.php/svg/core/actions/add/000?v=1’);–icon-add-fff: url(’/index.php/svg/core/actions/add/fff?v=1’);–icon-address-000: url(’/index.php/svg/core/actions/address/000?v=1’);–icon-address-fff: url(’/index.php/svg/core/actions/address/fff?v=1’);–icon-audio-000: url(’/index.php/svg/core/actions/audio/000?v=2’);–icon-audio-fff: url(’/index.php/svg/core/actions/audio/fff?v=2’);–icon-audio-off-000: url(’/index.php/svg/core/actions/audio-off/000?v=1’);–icon-audio-off-fff: url(’/index.php/svg/core/actions/audio-off/fff?v=1’);–icon-caret-fff: url(’/index.php/svg/core/actions/caret/fff?v=1’);–icon-caret-000: url(’/index.php/svg/core/actions/caret/000?v=1’);–icon-checkmark-000: url(’/index.php/svg/core/actions/checkmark/000?v=1’);–icon-checkmark-fff: url(’/index.php/svg/core/actions/checkmark/fff?v=1’);–icon-checkmark-46ba61: url(’/index.php/svg/core/actions/checkmark/46ba61?v=1’);–icon-clippy-000: url(’/index.php/svg/core/actions/clippy/000?v=2’);–icon-clippy-fff: url(’/index.php/svg/core/actions/clippy/fff?v=2’);–icon-close-000: url(’/index.php/svg/core/actions/close/000?v=1’);–icon-close-fff: url(’/index.php/svg/core/actions/close/fff?v=1’);–icon-comment-000: url(’/index.php/svg/core/actions/comment/000?v=1’);–icon-comment-fff: url(’/index.php/svg/core/actions/comment/fff?v=1’);–icon-confirm-000: url(’/index.php/svg/core/actions/confirm/000?v=2’);–icon-confirm-fff: url(’/index.php/svg/core/actions/confirm/fff?v=2’);–icon-download-000: url(’/index.php/svg/core/actions/download/000?v=1’);–icon-download-fff: url(’/index.php/svg/core/actions/download/fff?v=1’);–icon-delete-000: url(’/index.php/svg/core/actions/delete/000?v=1’);–icon-delete-e9322d: url(’/index.php/svg/core/actions/delete/e9322d?v=1’);–icon-delete-fff: url(’/index.php/svg/core/actions/delete/fff?v=1’);–icon-details-000: url(’/index.php/svg/core/actions/details/000?v=1’);–icon-details-fff: url(’/index.php/svg/core/actions/details/fff?v=1’);–icon-edit-000: url(’/index.php/svg/core/actions/edit/000?v=1’);–icon-edit-fff: url(’/index.php/svg/core/actions/edit/fff?v=1’);–icon-error-000: url(’/index.php/svg/core/actions/error/000?v=1’);–icon-error-fff: url(’/index.php/svg/core/actions/error/fff?v=1’);–icon-error-e9322d: url(’/index.php/svg/core/actions/error/e9322d?v=1’);–icon-external-000: url(’/index.php/svg/core/actions/external/000?v=1’);–icon-external-fff: url(’/index.php/svg/core/actions/external/fff?v=1’);–icon-fullscreen-000: url(’/index.php/svg/core/actions/fullscreen/000?v=1’);–icon-fullscreen-fff: url(’/index.php/svg/core/actions/fullscreen/fff?v=1’);–icon-history-000: url(’/index.php/svg/core/actions/history/000?v=2’);–icon-history-fff: url(’/index.php/svg/core/actions/history/fff?v=2’);–icon-info-000: url(’/index.php/svg/core/actions/info/000?v=1’);–icon-info-fff: url(’/index.php/svg/core/actions/info/fff?v=1’);–icon-logout-000: url(’/index.php/svg/core/actions/logout/000?v=1’);–icon-logout-fff: url(’/index.php/svg/core/actions/logout/fff?v=1’);–icon-mail-000: url(’/index.php/svg/core/actions/mail/000?v=1’);–icon-mail-fff: url(’/index.php/svg/core/actions/mail/fff?v=1’);–icon-menu-000: url(’/index.php/svg/core/actions/menu/000?v=1’);–icon-menu-fff: url(’/index.php/svg/core/actions/menu/fff?v=1’);–icon-more-000: url(’/index.php/svg/core/actions/more/000?v=1’);–icon-more-fff: url(’/index.php/svg/core/actions/more/fff?v=1’);–icon-password-000: url(’/index.php/svg/settings/password/000?v=1’);–icon-password-fff: url(’/index.php/svg/core/actions/password/fff?v=1’);–icon-pause-000: url(’/index.php/svg/core/actions/pause/000?v=1’);–icon-pause-fff: url(’/index.php/svg/core/actions/pause/fff?v=1’);–icon-play-000: url(’/index.php/svg/core/actions/play/000?v=1’);–icon-play-fff: url(’/index.php/svg/core/actions/play/fff?v=1’);–icon-play-add-000: url(’/index.php/svg/core/actions/play-add/000?v=1’);–icon-play-add-fff: url(’/index.php/svg/core/actions/play-add/fff?v=1’);–icon-play-next-000: url(’/index.php/svg/core/actions/play-next/000?v=1’);–icon-play-next-fff: url(’/index.php/svg/core/actions/play-next/fff?v=1’);–icon-play-previous-000: url(’/index.php/svg/core/actions/play-previous/000?v=1’);–icon-play-previous-fff: url(’/index.php/svg/core/actions/play-previous/fff?v=1’);–icon-public-000: url(’/index.php/svg/core/actions/public/000?v=1’);–icon-public-fff: url(’/index.php/svg/core/actions/public/fff?v=1’);–icon-quota-000: url(’/index.php/svg/core/actions/quota/000?v=1’);–icon-quota-fff: url(’/index.php/svg/core/actions/quota/fff?v=1’);–icon-rename-000:
Hi all,
sorry für die schlechte Formatierung oben in der Frage. Ich weiss nicht genau, wie ich CODE kennzeichne hier im Editor…
Ich habe im Apache Errorlog noch die folgende Info gefunden:
[Thu Nov 01 12:30:57.613551 2018] [php7:error] [pid 33] [client 5.10.x.x:45080] PHP Fatal error: Uncaught PDOException: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction in /var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php:105\nStack trace:\n#0 /var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php(105): PDOStatement->execute(NULL)\n#1 /var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(1006): Doctrine\DBAL\Driver\PDOStatement->execute()\n#2 /var/www/html/lib/private/DB/Connection.php(216): Doctrine\DBAL\Connection->executeUpdate(‘UPDATE oc_file...', Array, Array)\n#3 /var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php(208): OC\\DB\\Connection->executeUpdate('UPDATEoc_file…’, Array, Array)\n#4 /var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php(214): Doctrine\DBAL\Query\QueryBuilder->execute()\n#5 /var/www/html/lib/private/Lock/DBLockingProvider.php(310): OC\DB\QueryBuilder\QueryBuilder->execute()\n#6 [internal function]: OC\Lock\DBLockingProvide in /var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php on line 115
Was könnte die Ursache sein? Über einen Tipp würde ich mich sehr freuen… :slight_smile:
Vielen Dank,
Tabb
Guten Morgen,
niemand eine Idee?
Also den Hauch einer Reaktion hätte ich schon erwartet, zumindest einen Hinweis auf die Regel die ich verletzt habe wenn dem so sein sollte.
So ist dieses Forum leider nicht wirklich eine Hilfe…
