11.0.0
Linux 5.15.0-141-generic x86_64
- PHP version (e.g, 8.3):
Version: 8.3.21
no
months ago
AIO
no
Since the start, I have had intermittent issues with Nextloud Office, on the backend saying it can not connect. Looking around on Google, I see lots of mentions of DNS causing issues, maybe the issue.
I then installed on our Cloudron server, Collabora and use that installation.
Firstly, I then noticed whenever the server restarted that the settings to point to the Cloudron install of Collabora Office revert automatically to nextclouds install of Collabora Office. Tad annoying!
Secondly, I have noticed right after updating containers to Nextcloud 11.0.0 and going to the admin page of Nextcloud office that the server has magically started working again. Now, the last time prior to this time when I found the office was not working, I noticed it started to work again after a container update.
- I found this out when I tried to work on a document and it was not working, so I checked the admin page for it, and it had reverted back to the Nextcloud install of Collabora. I set it back to the Cloudron install of Collabora. Then I completed some work.
- After I went to check to see if any updates were needed on Nextcloud and apps. We found there was an update to 11.0.0 via AIO, so we did that.
- We then went to the admin page of Office to reset our cloudron install of collabora to find the nextcloud install of collabora as we thought it was an intermittent DNS issue, to find it has started to work again.
This seems to be a common occurrence that Nextcloud works with its own install of Collabora for a short time, then stops for no reason and at night, we have noticed, never stops during the day. Then starts to work after a container update!
- Has anyone else had this issue?
- Could this be something to do with backups at night?
- It can’t be a coincidence that every time there is an update for containers via the AIO install that Nextcloud Office works again?
Logs
systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2025-06-10T14:03:04.727033126Z frk-00013-00172 2025-06-10 15:03:04.726878 +0100 [ kit_spare_006 ] WRN #-14: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:03:04.728765375Z wsd-00007-00012 2025-06-10 15:03:04.728667 +0100 [ prisoner_poll ] WRN #22: Unassociated Kit (165) disconnected unexpectedly| wsd/COOLWSD.cpp:2943
2025-06-10T14:03:04.728777155Z wsd-00007-00012 2025-06-10 15:03:04.728718 +0100 [ prisoner_poll ] WRN #22: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:03:04.730256178Z frk-00013-00013 2025-06-10 15:03:04.730142 +0100 [ forkit ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2025-06-10T14:03:04.730337426Z frk-00013-00173 2025-06-10 15:03:04.730218 +0100 [ kit_spare_007 ] WRN #-14: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:03:04.734490261Z frk-00013-00174 2025-06-10 15:03:04.734230 +0100 [ kit_spare_008 ] WRN #-14: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:03:05.068716229Z kit-00174-00174 2025-06-10 15:03:05.068453 +0100 [ kit_spare_008 ] ERR Failed to get the realpath of [/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template] (ENOENT: No such file or directory)| common/FileUtil-unix.cpp:63
2025-06-10T14:03:05.068756118Z kit-00174-00174 2025-06-10 15:03:05.068544 +0100 [ kit_spare_008 ] ERR linkOrCopy: nftw() failed for ‘/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template’| kit/Kit.cpp:612
2025-06-10T14:03:05.069774229Z kit-00172-00172 2025-06-10 15:03:05.069389 +0100 [ kit_spare_006 ] ERR Failed to get the realpath of [/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template] (ENOENT: No such file or directory)| common/FileUtil-unix.cpp:63
2025-06-10T14:03:05.069797779Z kit-00172-00172 2025-06-10 15:03:05.069653 +0100 [ kit_spare_006 ] ERR linkOrCopy: nftw() failed for ‘/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template’| kit/Kit.cpp:612
2025-06-10T14:03:05.079747527Z kit-00173-00173 2025-06-10 15:03:05.079599 +0100 [ kit_spare_007 ] ERR Failed to get the realpath of [/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template] (ENOENT: No such file or directory)| common/FileUtil-unix.cpp:63
2025-06-10T14:03:05.079783386Z kit-00173-00173 2025-06-10 15:03:05.079742 +0100 [ kit_spare_007 ] ERR linkOrCopy: nftw() failed for ‘/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template’| kit/Kit.cpp:612
2025-06-10T14:03:05.169918689Z frk-00013-00013 2025-06-10 15:03:05.169737 +0100 [ forkit ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2025-06-10T14:03:05.175694903Z wsd-00007-00012 2025-06-10 15:03:05.175372 +0100 [ prisoner_poll ] WRN #22: Unassociated Kit (174) disconnected unexpectedly| wsd/COOLWSD.cpp:2943
2025-06-10T14:03:05.175729802Z wsd-00007-00012 2025-06-10 15:03:05.175426 +0100 [ prisoner_poll ] WRN #22: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:03:05.175825170Z wsd-00007-00012 2025-06-10 15:03:05.175678 +0100 [ prisoner_poll ] WRN #27: Unassociated Kit (172) disconnected unexpectedly| wsd/COOLWSD.cpp:2943
2025-06-10T14:03:05.175849851Z wsd-00007-00012 2025-06-10 15:03:05.175697 +0100 [ prisoner_poll ] WRN #27: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:03:05.178727778Z frk-00013-00181 2025-06-10 15:03:05.178360 +0100 [ kit_spare_009 ] WRN #-14: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:03:05.178964943Z wsd-00007-00012 2025-06-10 15:03:05.178863 +0100 [ prisoner_poll ] WRN #29: Unassociated Kit (173) disconnected unexpectedly| wsd/COOLWSD.cpp:2943
2025-06-10T14:03:05.178975703Z wsd-00007-00012 2025-06-10 15:03:05.178898 +0100 [ prisoner_poll ] WRN #29: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:03:05.531830250Z kit-00181-00181 2025-06-10 15:03:05.531610 +0100 [ kit_spare_009 ] ERR Failed to get the realpath of [/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template] (ENOENT: No such file or directory)| common/FileUtil-unix.cpp:63
2025-06-10T14:03:05.531860481Z kit-00181-00181 2025-06-10 15:03:05.531705 +0100 [ kit_spare_009 ] ERR linkOrCopy: nftw() failed for ‘/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template’| kit/Kit.cpp:612
2025-06-10T14:03:35.167515329Z frk-00013-00013 2025-06-10 15:03:35.166957 +0100 [ forkit ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2025-06-10T14:03:35.173997290Z frk-00013-00013 2025-06-10 15:03:35.173551 +0100 [ forkit ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2025-06-10T14:03:35.174302585Z frk-00013-00207 2025-06-10 15:03:35.174053 +0100 [ kit_spare_00a ] WRN #-14: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:03:35.179478661Z frk-00013-00013 2025-06-10 15:03:35.179129 +0100 [ forkit ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2025-06-10T14:03:35.180114509Z frk-00013-00208 2025-06-10 15:03:35.179812 +0100 [ kit_spare_00b ] WRN #-14: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:03:35.189590395Z frk-00013-00209 2025-06-10 15:03:35.189123 +0100 [ kit_spare_00c ] WRN #-14: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:03:35.533829761Z kit-00207-00207 2025-06-10 15:03:35.533531 +0100 [ kit_spare_00a ] ERR Failed to get the realpath of [/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template] (ENOENT: No such file or directory)| common/FileUtil-unix.cpp:63
2025-06-10T14:03:35.533855580Z kit-00207-00207 2025-06-10 15:03:35.533641 +0100 [ kit_spare_00a ] ERR linkOrCopy: nftw() failed for ‘/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template’| kit/Kit.cpp:612
2025-06-10T14:03:35.538150222Z kit-00209-00209 2025-06-10 15:03:35.537992 +0100 [ kit_spare_00c ] ERR Failed to get the realpath of [/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template] (ENOENT: No such file or directory)| common/FileUtil-unix.cpp:63
2025-06-10T14:03:35.538166442Z kit-00209-00209 2025-06-10 15:03:35.538048 +0100 [ kit_spare_00c ] ERR linkOrCopy: nftw() failed for ‘/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template’| kit/Kit.cpp:612
2025-06-10T14:03:35.593093557Z kit-00208-00208 2025-06-10 15:03:35.592806 +0100 [ kit_spare_00b ] ERR Failed to get the realpath of [/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template] (ENOENT: No such file or directory)| common/FileUtil-unix.cpp:63
2025-06-10T14:03:35.593121487Z kit-00208-00208 2025-06-10 15:03:35.592916 +0100 [ kit_spare_00b ] ERR linkOrCopy: nftw() failed for ‘/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template’| kit/Kit.cpp:612
2025-06-10T14:05:11.107138318Z wsd-00007-00028 2025-06-10 15:05:11.106953 +0100 [ websrv_poll ] WRN #30: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:19:27.512827808Z wsd-00007-00028 2025-06-10 15:19:27.512391 +0100 [ websrv_poll ] ERR FileServerRequestHandler: File not found: Invalid URI request (hash): [/browser/0968141f2c/color-palette.css].| wsd/FileServer.cpp:1173
2025-06-10T14:19:27.516435105Z wsd-00007-00028 2025-06-10 15:19:27.516306 +0100 [ websrv_poll ] ERR FileServerRequestHandler: File not found: Invalid URI request (hash): [/browser/0968141f2c/color-palette-dark.css].| wsd/FileServer.cpp:1173
2025-06-10T14:19:27.568927567Z wsd-00007-00028 2025-06-10 15:19:27.568669 +0100 [ websrv_poll ] ERR FileServerRequestHandler: File not found: Invalid URI request (hash): [/browser/0968141f2c/l10n.js].| wsd/FileServer.cpp:1173
2025-06-10T14:19:27.716607248Z wsd-00007-00028 2025-06-10 15:19:27.716427 +0100 [ websrv_poll ] WRN Client - server version mismatch, disabling browser cache. Expected: 0968141f2c; Actual URI path with version hash: /browser/dist/fetch-settings-config| wsd/FileServer.cpp:913
2025-06-10T14:19:27.889228471Z wsd-00007-00028 2025-06-10 15:19:27.888990 +0100 [ websrv_poll ] WRN Client - server version mismatch, disabling browser cache. Expected: 0968141f2c; Actual URI path with version hash: /browser/dist/fetch-settings-file| wsd/FileServer.cpp:913
2025-06-10T14:21:27.532334723Z wsd-00007-00028 2025-06-10 15:21:27.532141 +0100 [ websrv_poll ] WRN #30: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:21:27.992400156Z wsd-00007-00028 2025-06-10 15:21:27.992163 +0100 [ websrv_poll ] WRN #32: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:43:41.874751489Z frk-00013-00013 2025-06-10 15:43:41.873354 +0100 [ forkit ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2025-06-10T14:43:41.912260492Z frk-00013-00774 2025-06-10 15:43:41.911790 +0100 [ kit_spare_00d ] WRN #-14: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:43:42.626669436Z kit-00774-00774 2025-06-10 15:43:42.626241 +0100 [ kit_spare_00d ] ERR Failed to get the realpath of [/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template] (ENOENT: No such file or directory)| common/FileUtil-unix.cpp:63
2025-06-10T14:43:42.626694926Z kit-00774-00774 2025-06-10 15:43:42.626524 +0100 [ kit_spare_00d ] ERR linkOrCopy: nftw() failed for ‘/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template’| kit/Kit.cpp:612
2025-06-10T14:43:42.932179541Z wsd-00007-00770 2025-06-10 15:43:42.931982 +0100 [ docbroker_001 ] WRN #17: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:48:28.308111582Z frk-00013-00013 2025-06-10 15:48:28.307582 +0100 [ forkit ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2025-06-10T14:48:28.321565402Z frk-00013-00852 2025-06-10 15:48:28.321033 +0100 [ kit_spare_00e ] WRN #-14: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:48:28.694028367Z kit-00852-00852 2025-06-10 15:48:28.693825 +0100 [ kit_spare_00e ] ERR Failed to get the realpath of [/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template] (ENOENT: No such file or directory)| common/FileUtil-unix.cpp:63
2025-06-10T14:48:28.694066346Z kit-00852-00852 2025-06-10 15:48:28.693918 +0100 [ kit_spare_00e ] ERR linkOrCopy: nftw() failed for ‘/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template’| kit/Kit.cpp:612
2025-06-10T14:48:28.881388663Z frk-00013-00013 2025-06-10 15:48:28.881046 +0100 [ forkit ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2025-06-10T14:48:28.888530946Z frk-00013-00870 2025-06-10 15:48:28.888317 +0100 [ kit_spare_00f ] WRN #-14: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:48:29.173951293Z wsd-00007-00849 2025-06-10 15:48:29.173739 +0100 [ docbroker_002 ] ERR ToClient-044: Error saveas socket missing in isConvertTo mode| wsd/ClientSession.cpp:2314
2025-06-10T14:48:29.213242162Z wsd-00007-00869 2025-06-10 15:48:29.212874 +0100 [ docbroker_003 ] ERR ToClient-045: Error saveas socket missing in isConvertTo mode| wsd/ClientSession.cpp:2314
2025-06-10T14:48:29.219966782Z wsd-00007-00849 2025-06-10 15:48:29.219811 +0100 [ docbroker_002 ] WRN #28: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:48:29.245190122Z kit-00870-00870 2025-06-10 15:48:29.244451 +0100 [ kit_spare_00f ] ERR Failed to get the realpath of [/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template] (ENOENT: No such file or directory)| common/FileUtil-unix.cpp:63
2025-06-10T14:48:29.245212632Z kit-00870-00870 2025-06-10 15:48:29.244615 +0100 [ kit_spare_00f ] ERR linkOrCopy: nftw() failed for ‘/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template’| kit/Kit.cpp:612
2025-06-10T14:48:29.247148117Z wsd-00007-00869 2025-06-10 15:48:29.247036 +0100 [ docbroker_003 ] WRN #33: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:48:29.642139549Z frk-00013-00013 2025-06-10 15:48:29.641939 +0100 [ forkit ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2025-06-10T14:48:29.648833649Z frk-00013-00013 2025-06-10 15:48:29.648704 +0100 [ forkit ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2025-06-10T14:48:29.649300371Z frk-00013-00931 2025-06-10 15:48:29.648930 +0100 [ kit_spare_010 ] WRN #-14: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:48:29.655139437Z frk-00013-00932 2025-06-10 15:48:29.654928 +0100 [ kit_spare_011 ] WRN #-14: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:48:29.677517847Z wsd-00007-00885 2025-06-10 15:48:29.677364 +0100 [ docbroker_004 ] ERR ToClient-046: Error saveas socket missing in isConvertTo mode| wsd/ClientSession.cpp:2314
2025-06-10T14:48:29.712387335Z wsd-00007-00885 2025-06-10 15:48:29.712228 +0100 [ docbroker_004 ] WRN #31: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:48:29.887006119Z wsd-00007-00910 2025-06-10 15:48:29.886816 +0100 [ docbroker_005 ] ERR ToClient-047: Error saveas socket missing in isConvertTo mode| wsd/ClientSession.cpp:2314
2025-06-10T14:48:29.920427843Z wsd-00007-00910 2025-06-10 15:48:29.920017 +0100 [ docbroker_005 ] WRN #25: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:48:29.998469461Z kit-00932-00932 2025-06-10 15:48:29.998294 +0100 [ kit_spare_011 ] ERR Failed to get the realpath of [/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template] (ENOENT: No such file or directory)| common/FileUtil-unix.cpp:63
2025-06-10T14:48:29.998498880Z kit-00932-00932 2025-06-10 15:48:29.998362 +0100 [ kit_spare_011 ] ERR linkOrCopy: nftw() failed for ‘/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template’| kit/Kit.cpp:612
2025-06-10T14:48:30.001590625Z kit-00931-00931 2025-06-10 15:48:30.001289 +0100 [ kit_spare_010 ] ERR Failed to get the realpath of [/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template] (ENOENT: No such file or directory)| common/FileUtil-unix.cpp:63
2025-06-10T14:48:30.001600994Z kit-00931-00931 2025-06-10 15:48:30.001359 +0100 [ kit_spare_010 ] ERR linkOrCopy: nftw() failed for ‘/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template’| kit/Kit.cpp:612
2025-06-10T14:48:45.824410070Z frk-00013-00013 2025-06-10 15:48:45.824167 +0100 [ forkit ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2025-06-10T14:48:45.830846805Z frk-00013-00953 2025-06-10 15:48:45.830593 +0100 [ kit_spare_012 ] WRN #-14: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
2025-06-10T14:48:46.160735067Z kit-00953-00953 2025-06-10 15:48:46.160476 +0100 [ kit_spare_012 ] ERR Failed to get the realpath of [/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template] (ENOENT: No such file or directory)| common/FileUtil-unix.cpp:63
2025-06-10T14:48:46.160760327Z kit-00953-00953 2025-06-10 15:48:46.160566 +0100 [ kit_spare_012 ] ERR linkOrCopy: nftw() failed for ‘/opt/cool/child-roots/7-fa4bea98/tmp/sharedpresets/template’| kit/Kit.cpp:612
2025-06-10T14:48:46.273756399Z wsd-00007-00952 2025-06-10 15:48:46.273476 +0100 [ docbroker_006 ] WRN #29: Socket still open post onDisconnect(), forced shutdown.| net/Socket.hpp:1263
