Recently migrated from Docker running in a debian jail to Native Docker in TrueNAS Scale
Running version 20241106_101604
Nextcloud intermittently becomes unresponsive
Logs
nextcloud-aio-apache | Waiting for Nextcloud to start...
nextcloud-aio-database | Setting postgres values...
nextcloud-aio-database | PostgreSQL Database directory appears to contain a database; Skipping initialization
nextcloud-aio-notify-push | nc: getaddrinfo for host "nextcloud-aio-nextcloud" port 9001: Name does not resolve
nextcloud-aio-notify-push | Waiting for Nextcloud to start...
nextcloud-aio-database | 2024-11-12 17:26:32.891 CST [14] LOG: starting PostgreSQL 16.4 on x86_64-pc-linux-musl, compiled by gcc (Alpine 13.2.1_git20240309) 13.2.1 20240309, 64-bit
nextcloud-aio-database | 2024-11-12 17:26:32.891 CST [14] LOG: listening on IPv4 address "0.0.0.0", port 5432
nextcloud-aio-database | 2024-11-12 17:26:32.891 CST [14] LOG: listening on IPv6 address "::", port 5432
nextcloud-aio-nextcloud | Connection to nextcloud-aio-database (172.24.20.4) 5432 port [tcp/postgresql] succeeded!
nextcloud-aio-nextcloud | now
nextcloud-aio-database | 2024-11-12 17:26:33.071 CST [14] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
nextcloud-aio-database | 2024-11-12 17:26:33.383 CST [24] LOG: database system was shut down at 2024-11-12 17:25:39 CST
nextcloud-aio-database | 2024-11-12 17:26:33.391 CST [14] LOG: database system is ready to accept connections
nextcloud-aio-redis | Redis has started
nextcloud-aio-nextcloud | -------------------------------
nextcloud-aio-nextcloud | 2024-11-12 17:26:37.921291-06
nextcloud-aio-nextcloud | (1 row)
nextcloud-aio-nextcloud | + '[' -f /dev-dri-group-was-added ']'
nextcloud-aio-nextcloud | ++ find /dev -maxdepth 1 -mindepth 1 -name dri
nextcloud-aio-nextcloud | + '[' -n '' ']'
nextcloud-aio-nextcloud | + set +x
nextcloud-aio-nextcloud | Enabling Imagick...
nextcloud-aio-nextcloud | WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.20/main: No such file or directory
nextcloud-aio-nextcloud | WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.20/community: No such file or directory
nextcloud-aio-nextcloud | Connection to nextcloud-aio-redis (172.24.20.3) 6379 port [tcp/redis] succeeded!
nextcloud-aio-nextcloud | Applying one-click-instance settings...
nextcloud-aio-nextcloud | System config value one-click-instance set to boolean true
nextcloud-aio-nextcloud | System config value one-click-instance.user-limit set to integer 100
nextcloud-aio-nextcloud | System config value one-click-instance.link set to string https://nextcloud.com/all-in-one/
nextcloud-aio-nextcloud | support already enabled
nextcloud-aio-nextcloud | Adjusting log files...
nextcloud-aio-nextcloud | System config value upgrade.cli-upgrade-link set to string https://github.com/nextcloud/all-in-one/discussions/2726
nextcloud-aio-nextcloud | System config value logfile set to string /var/www/html/data/nextcloud.log
nextcloud-aio-nextcloud | Config value were not updated
nextcloud-aio-nextcloud | System config value updatedirectory set to string /nc-updater
nextcloud-aio-nextcloud | System config value maintenance_window_start set to integer 100
nextcloud-aio-nextcloud | Applying network settings...
nextcloud-aio-nextcloud | System config value allow_local_remote_servers set to boolean true
nextcloud-aio-nextcloud | System config value davstorage.request_timeout set to integer 3600
nextcloud-aio-nextcloud | System config value trusted_domains => 1 set to string nextcloud.domainredacted.net
nextcloud-aio-nextcloud | System config value overwrite.cli.url set to string https://nextcloud.domainredacted.net/
nextcloud-aio-nextcloud | System config value htaccess.RewriteBase set to string /
nextcloud-aio-nextcloud | .htaccess has been updated
nextcloud-aio-nextcloud | System config value dbpersistent set to boolean false
nextcloud-aio-nextcloud | System config value auth.bruteforce.protection.enabled set to boolean true
nextcloud-aio-nextcloud | System config value ratelimit.protection.enabled set to boolean true
nextcloud-aio-nextcloud | System config value files_external_allow_create_new_local set to boolean false
nextcloud-aio-nextcloud | No such app enabled: nextcloud-aio
nextcloud-aio-nextcloud | notify_push is up-to-date or no updates could be found
nextcloud-aio-nextcloud | System config value trusted_proxies => 0 set to string 127.0.0.1
nextcloud-aio-nextcloud | System config value trusted_proxies => 1 set to string ::1
nextcloud-aio-nextcloud | System config value trusted_proxies => 2 set to string 172.24.0.0/23
nextcloud-aio-nextcloud | System config value trusted_proxies => 10 set to string 172.24.20.0/16
nextcloud-aio-nextcloud | + '[' '' = true ']'
nextcloud-aio-nextcloud | [12-Nov-2024 17:27:16] NOTICE: fpm is running, pid 356
nextcloud-aio-nextcloud | [12-Nov-2024 17:27:16] NOTICE: ready to handle connections
nextcloud-aio-apache | Connection to nextcloud-aio-nextcloud (172.24.20.5) 9000 port [tcp/*] succeeded!
nextcloud-aio-notify-push | Connection to nextcloud-aio-nextcloud (172.24.20.5) 9001 port [tcp/*] succeeded!
nextcloud-aio-notify-push | notify-push was started
nextcloud-aio-apache | [Tue Nov 12 17:27:21.487272 2024] [mpm_event:notice] [pid 67:tid 67] AH00489: Apache/2.4.62 (Unix) configured -- resuming normal operations
nextcloud-aio-apache | [Tue Nov 12 17:27:21.487342 2024] [core:notice] [pid 67:tid 67] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
nextcloud-aio-apache | {"level":"info","ts":1731454041.5182633,"msg":"using config from file","file":"/tmp/Caddyfile"}
nextcloud-aio-apache | {"level":"info","ts":1731454041.5205348,"msg":"adapted config to JSON","adapter":"caddyfile"}
Logs appear completely clean… If the containers are destroyed and rebuild it may more may not come up with no noticeable difference in the logs
Docker Compose (Collabra, Only Office and Full text search were removed for trouble shooting
networks:
nextcloud:
ipam:
driver: default
config:
- subnet: 172.24.20.0/24
ip_range: 172.24.20.0/24
gateway: 172.24.20.1
proxy:
external: true
services:
nextcloud-aio-apache:
container_name: nextcloud-aio-apache
depends_on:
nextcloud-aio-nextcloud:
condition: service_started
required: false
nextcloud-aio-notify-push:
required: false
image: nextcloud/aio-apache:${VERSION}
user: 33:0
init: true
expose:
- 11000
environment:
- NC_DOMAIN=${NC_DOMAIN}
- NEXTCLOUD_HOST=${NEXTCLOUD_HOST}
- APACHE_HOST=${APACHE_HOST}
- APACHE_PORT=${APACHE_PORT}
- TZ=${TIMEZONE}
- APACHE_MAX_SIZE=${APACHE_MAX_SIZE}
- APACHE_MAX_TIME=${NEXTCLOUD_MAX_TIME}
- NOTIFY_PUSH_HOST=${NOTIFY_HOST}
volumes:
- ${NEXTCLOUD_DATA}:/var/www/html:ro
- ${APACHE_DATA}:/mnt/data:rw
restart: unless-stopped
networks:
- proxy
- nextcloud
labels:
- traefik.enable=true
- traefik.http.routers.nextcloud.entrypoints=websecure
- traefik.http.routers.nextcloud.rule=Host(`${NC_DOMAIN}`)
- traefik.http.routers.nextcloud.tls=true
- traefik.http.services.nextcloud.loadbalancer.server.port=11000
- traefik.http.routers.nextcloud.middlewares=nextcloud-secure-headers
- traefik.http.middlewares.nextcloud-secure-headers.headers.hostsProxyHeaders=X-Forwarded-Host
- traefik.http.middlewares.nextcloud-secure-headers.headers.referrerPolicy=same-origin
read_only: true
tmpfs:
- /var/log/supervisord
- /var/run/supervisord
- /usr/local/apache2/logs
- /tmp
- /home/www-data
cap_drop:
- NET_RAW
deploy:
resources:
limits:
cpus: "2"
memory: 4G
nextcloud-aio-database:
container_name: nextcloud-aio-database
image: nextcloud/aio-postgresql:${VERSION}
user: 999:0
init: true
expose:
- 5432
volumes:
- ${DATABASE_DATA}:/var/lib/postgresql/data:rw
- ${DATABASE_DUMP_DATA}:/mnt/data:rw
environment:
- POSTGRES_PASSWORD=${DATABASE_PASSWORD}
- POSTGRES_DB=nextcloud_database
- POSTGRES_USER=nextcloud
- TZ=${TIMEZONE}
- PGTZ=${TIMEZONE}
stop_grace_period: 1800s
shm_size: 268435456
networks:
- nextcloud
read_only: true
tmpfs:
- /var/run/postgresql:uid=999,gid=0,mode=0755
cap_drop:
- NET_RAW
deploy:
resources:
limits:
cpus: "2"
memory: 4G
container_name: nextcloud-aio-nextcloud
depends_on:
required: false
nextcloud-aio-redis:
required: false
image: nextcloud/aio-nextcloud:${VERSION}
user: 0:0
init: true
expose:
- 9000
- 9001
volumes:
- ${NEXTCLOUD_DATA}:/var/www/html:rw
- ${NEXTCLOUD_DATADIR}:/mnt/ncdata:rw
#- ${NEXTCLOUD_MOUNT}:${NEXTCLOUD_MOUNT}:rw
#- ${NEXTCLOUD_TRUSTED_CACERTS_DIR}:/usr/local/share/ca-certificates:ro
environment:
- POSTGRES_HOST=${DATABASE_HOST}
- POSTGRES_PORT=5432
- REDIS_HOST=${REDIS_HOST}
- REDIS_HOST_PASSWORD=${REDIS_PASSWORD}
- ADMIN_USER=admin
- ADMIN_PASSWORD=${NEXTCLOUD_PASSWORD}
- NEXTCLOUD_DATA_DIR=/mnt/ncdata
- OVERWRITEHOST=${NC_DOMAIN}
- OVERWRITEPROTOCOL=https
- TURN_SECRET=${TURN_SECRET}
- SIGNALING_SECRET=${SIGNALING_SECRET}
- ONLYOFFICE_SECRET=${ONLYOFFICE_SECRET}
- CLAMAV_ENABLED=${CLAMAV_ENABLED}
- ONLYOFFICE_ENABLED=${ONLYOFFICE_ENABLED}
- COLLABORA_ENABLED=${COLLABORA_ENABLED}
- COLLABORA_HOST=${COLLABORA_HOST}
- TALK_ENABLED=${TALK_ENABLED}
- ONLYOFFICE_HOST=${ONLYOFFICE_HOST}
- UPDATE_NEXTCLOUD_APPS=${UPDATE_NEXTCLOUD_APPS}
- TZ=${TIMEZONE}
- IMAGINARY_ENABLED=${IMAGINARY_ENABLED}
- IMAGINARY_HOST=${IMAGINARY_HOST}
- PHP_UPLOAD_LIMIT=${NEXTCLOUD_UPLOAD_LIMIT}
- PHP_MEMORY_LIMIT=${NEXTCLOUD_MEMORY_LIMIT}
- FULLTEXTSEARCH_ENABLED=${FULLTEXTSEARCH_ENABLED}
- FULLTEXTSEARCH_HOST=${FULLTEXT_HOST}
- PHP_MAX_TIME=${NEXTCLOUD_MAX_TIME}
- STARTUP_APPS=${NEXTCLOUD_STARTUP_APPS}
- ADDITIONAL_APKS=${NEXTCLOUD_ADDITIONAL_APKS}
- ADDITIONAL_PHP_EXTENSIONS=${NEXTCLOUD_ADDITIONAL_PHP_EXTENSIONS}
- INSTALL_LATEST_MAJOR=${INSTALL_LATEST_MAJOR}
- FULLTEXTSEARCH_PASSWORD=${FULLTEXTSEARCH_PASSWORD}
- REMOVE_DISABLED_APPS=${REMOVE_DISABLED_APPS}
- IMAGINARY_SECRET=${IMAGINARY_SECRET}
- ADDITIONAL_TRUSTED_PROXY=${ADDITIONAL_TRUSTED_PROXY}
stop_grace_period: 600s
networks:
- nextcloud
cap_drop:
- NET_RAW
deploy:
resources:
limits:
cpus: "4"
memory: 8G
container_name: nextcloud-aio-notify-push
image: nextcloud/aio-notify-push:${VERSION}
user: 33:0
init: true
expose:
- 7867
volumes:
- ${NEXTCLOUD_DATA}:/nextcloud:ro
environment:
networks:
- nextcloud
read_only: true
cap_drop:
- NET_RAW
deploy:
resources:
limits:
cpus: "2"
memory: 4G
container_name: nextcloud-aio-redis
image: nextcloud/aio-redis:${VERSION}
user: 999:0
init: true
expose:
- 6379
environment:
- TZ=${TIMEZONE}
volumes:
- ${REDIS_DATA}:/data:rw
networks:
- nextcloud
read_only: true
cap_drop:
- NET_RAW
deploy:
resources:
limits:
cpus: "2"
memory: 4G
Questions
Could this be a kernel issue?
fs.inotify.max_user_watches set to 4962130
fs.inotify.max_user_instances set to 8000
all others default for the OS -
Otherwise could this be a permission issue?
