Nextcloud version: 11.0.2
Operating system and version: Debian GNU/Linux 8
Apache or nginx version: nginx/1.6.2
PHP version: 5.6.29
Is this the first time you’ve seen this error and can you replicate it?: yes
In my ownCloud Docker Container I have a run.sh script that changes some settings in the the /var/www/owncloud/.user.ini file:
sed -i \
-e 's/^upload_max_filesize=.*/upload_max_filesize=5G/g' \
-e 's/^post_max_size=.*/post_max_size=5G/g' \
-e 's/^memory_limit=.*/memory_limit=2048M/g' \
When I now run the container and sign in I get this error message:
Some files have not passed the integrity check. Further information on how to resolve this issue can be found in our documentation. (List of invalid files… / Rescan…)
Results
- core
- INVALID_HASH
- .user.ini
no errors
The output of your config.php file:
<?php $CONFIG = array ( 'memcache.local' => '\OC\Memcache\APCu', 'instanceid' => 'ocfefka6wthy', 'passwordsalt' => 'thisisnotmypassword', 'secret' => 'thisisnotmysecret', 'trusted_domains' => array ( 0 => 'customername.ourdomain.ch', ), 'datadirectory' => '/var/www/owncloud/data', 'overwrite.cli.url' => 'https://customername.ourdomain.ch', 'dbtype' => 'mysql', 'version' => '11.0.2.7', 'dbname' => 'ocdb', 'dbhost' => '10.64.51.5', 'dbport' => '', 'dbtableprefix' => 'oc_', 'dbuser' => 'ocuser', 'dbpassword' => 'thisisnotmypassword', 'logtimezone' => 'Europe/Zurich', 'installed' => true, 'updatechecker' => 'false', 'default_language' => 'de', 'log_rotate_size' => '104857600', 'maintenance' => false, 'theme' => '', 'loglevel' => 2, );
The output of your nginx log:
no errors
Is there a way to set those settings without this integrity check error message?
Thanks a lot!
