I migrated from owncloud to Nextcloud 10 today and I followed this guide, https://www.techandme.se/we-migrated-to-nextcloud-10-0-1/ but got some code itegrity check after. I think the problem has some clue here, I executed this command for the backup, “sudo cp -R /var/www/owncloud/config /var/ocbackup/” from the guide and now after everything is done and Nextcloud is running the Integrity check says this is wrong
Results
core
EXTRA_FILE
ocbackup/.htaccess
ocbackup/disable-updatechecker.config.php
ocbackup/config.php
ocbackup/config.sample.php
ocbackup/config.php.old
ocbackup/config/config.php
I then entered the folder and listed it and this gave this answer
/var/ocbackup# ls
config config.php config.php.old config.sample.php disable-updatechecker.config.php
I then moved all these files to a temporary folder but the problem still appears in Nextcloud.
mv * /home/myuser/tmp/
The problem is that there are now files in the Nextcloud server - folder which should not be there … Please remove those files “ocbackup/**” from the directory by moving them out - or deleting them … After that, please reload and do this Integrity check again. It should work now
Yes I know this but I have already removed the files and now I removed the whole folder and then manually create it again but still the same problem
cd /var/ocbackup/
root@web01:/var/ocbackup# ls
root@web01:/var/ocbackup# cd …
root@web01:/var# rm -r ocbackup/
root@web01:/var# ls
backups cache lib local lock log mail opt run spool tmp www
root@web01:/var# mkdir ocbackup
And after rescan
Technical information
The following list covers which files have failed the integrity check. Please read
the previous linked documentation to learn more about the errors and how to fix
them.
Results
core
EXTRA_FILE
ocbackup/.htaccess
ocbackup/config.php
But folder is empty
root@web01:/var# cd ocbackup/
root@web01:/var/ocbackup# ls -l
total 0
You have deleted the files, mentioned under EXTRA_FILE in the directory of your Nextcloud instance
…and you have also rescanned?
And you are still seeing these files in the check? …could you send me the folder-structure of your Nextcloud instance (root)? (apps, core, config, … and all the other folders and files you see in your Nextcloud folder)
