nitda
February 22, 2018, 4:01pm
#1
After resolving upgrade issue I have integrity error. please I need assistance.
see below the info
Technical information
The following list covers which files have failed the integrity check. Please read
the previous linked documentation to learn more about the errors and how to fix
them.
Results
Raw output
Array
[core] => Array
[EXTRA_FILE] => Array
[.config.php.swp] => Array
[expected] =>
[current] => 9735cf5d4c08a40e2422a3c4e3713d8817e91ff99c8e7d511b0446189bd1fe0a0d9e8ff45abf4275be25d2554cdf92862e788c889178dada6f7a37a4feadd624
Schmu
February 22, 2018, 4:29pm
#2
If you need the file
nextcloud/config/.config.php.swp
for any reason, please move it out of the nextcloud directories and save it for example in the user’s home folder (e.g. /root).
After that run the integrity check again.
nitda
February 23, 2018, 7:51am
#3
Thanks for the response…the file is not in nextcloud/config/ folder. please how to locate it
nitda
March 1, 2018, 4:30pm
#5
Sorry for the delay…yes i did. please find below the ls -al
total 128
drwxr-xr-x 14 www-data www-data 4096 Feb 22 06:48 .
drwxr-xr-x 5 root root 4096 Jul 28 2017 …
drwxr-xr-x 33 www-data www-data 4096 Feb 8 09:23 3rdparty
drwxr-xr-x 60 www-data www-data 4096 Feb 22 06:49 apps
-rw-r–r-- 1 www-data www-data 12063 Feb 8 09:23 AUTHORS
drwxr-x— 2 www-data www-data 4096 Feb 22 07:04 config
-rw-r–r-- 1 root root 1024 Feb 22 06:48 .config.php.swp
-rwxr-xr-x 1 www-data www-data 3593 Feb 8 09:23 console.php
drwxr-xr-x 17 www-data www-data 4096 Feb 8 09:23 core
-rw-r–r-- 1 www-data www-data 4946 Feb 8 09:23 cron.php
-rw-r–r-- 1 www-data www-data 3917 Feb 16 17:27 .htaccess
-rw-r–r-- 1 www-data www-data 179 Feb 8 09:23 index.html
-rw-r–r-- 1 www-data www-data 3417 Feb 8 09:23 index.php
drwxr-xr-x 3 www-data www-data 4096 Feb 8 09:23 l10n
drwxr-xr-x 6 www-data www-data 4096 Feb 8 09:23 lib
-rwxr-xr-x 1 www-data www-data 283 Feb 8 09:23 occ
drwxr-xr-x 2 www-data www-data 4096 Feb 8 09:23 ocs
drwxr-xr-x 2 www-data www-data 4096 Feb 8 09:23 ocs-provider
-rw-r–r-- 1 www-data www-data 3214 Feb 8 09:23 public.php
-rw-r–r-- 1 www-data www-data 5370 Feb 8 09:23 remote.php
drwxr-xr-x 4 www-data www-data 4096 Feb 8 09:23 resources
-rw-r–r-- 1 www-data www-data 26 Feb 8 09:23 robots.txt
drwxr-xr-x 14 www-data www-data 4096 Feb 8 09:23 settings
-rw-r–r-- 1 www-data www-data 2274 Feb 8 09:23 status.php
drwxr-xr-x 3 www-data www-data 4096 Feb 8 09:23 themes
drwxr-xr-x 2 www-data www-data 4096 Feb 8 09:32 updater
-rw-r–r-- 1 www-data www-data 163 Feb 8 09:23 .user.ini
-rw-r–r-- 1 www-data www-data 363 Feb 8 09:23 version.php
thanks for your assistance
Schmu
March 1, 2018, 5:27pm
#6
And here it is.
Just move this file to your home directory or delete it (if you no longer need it).
